Bad Zula #497 - Page 3 - Defender Source
Old April 30th, 2014, 09:06 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ok so two words Mola Lita...Wish I had done it sooner. Also for those of you like me that like to do things the hard way and waste more money by not using the right tool first...you absolutely cannot use a Craftsman lawnmower blade retainer as a steering wheel puller, even if you modify it...go spend the $14.00.
And yes the dog was supervising as usual...
ID:	94006   Click image for larger version
ID:	94008   Click image for larger version
Old May 5th, 2014, 12:46 PM
Bill Larson
Bill Larson
You know Mondays are GREAT when you get LR stuff delivered...received my Lelo Fab Bonnet Basket and it's BA. Will be making it's first public Expo debut at Overland...(optional bunny ears are extra...)
ID:	94256   Click image for larger version
ID:	94258   Click image for larger version
Old May 5th, 2014, 01:03 PM
The Dro
Dro
1988 Ninety
Originally Posted by Bill Larson View Post
You know Monday are GREAT when you get LR stuff delivered...received my Lelo Fab Bonnet Basket and it's BA. Will be making it's first public Expo debut at Overland...(optional bunny ears are extra...)
Yeah right... blame the poor dog. Those bunny ears were for you.
Old May 5th, 2014, 01:17 PM
Bill Larson
Bill Larson
No the Wabbit is for me...
Old May 6th, 2014, 08:59 AM
Bill Larson
Bill Larson
Well this is how it will look later tonight when she's done!...pretty freakin awesome!
ID:	94319   Click image for larger version
Old May 6th, 2014, 07:15 PM
Looks nice, what do you plan on putting in there? Beer cooler?
Old May 6th, 2014, 07:26 PM
101stAirborne's Avatar
101stAirborne
Battle Ewing
1997 D90 LE 255/300
You have to show some 360 photos if your trucks current setup!!!!
Old May 6th, 2014, 07:27 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
I'm thinking BBQ wood.
Old May 6th, 2014, 07:52 PM
Bill Larson
Bill Larson
It's where the dog will ride...1) Cause I hate dog hair...2) She's an adrenaline junkie!
That's what Briggs said also...what are you going to use that for?!? lol...
Old May 6th, 2014, 07:59 PM
You should spend some time with my Husky and you will appreciate the lack of dog hair you have to deal with.
Old May 6th, 2014, 08:10 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
This went on pretty easy... the mounting holes on either end didn't line up to my satisfaction so I'm leaving them for Matt to address in the summer when I go out for the rally. He's going to do some other smaller things also. Removing the old tire carrier was more difficult than mounting the bumper. After it was removed, I preped the holes with netralizer then seamed the area with gasket goop then I took and newer, no longer needed license plate and cut it to size and applied dynamat to bothe sides then rivited it in place. It's a temp job until I figure out what the final fix will be.
Bill, that rear Rock bumper with swing arm is my dream upgrade. Great work all around.
Old May 6th, 2014, 08:19 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Ok so two words Mola Lita...Wish I had done it sooner. Also for those of you like me that like to do things the hard way and waste more money by not using the right tool first...you absolutely cannot use a Craftsman lawnmower blade retainer as a steering wheel puller, even if you modify it...go spend the $14.00. And yes the dog was supervising as usual...
That steering wheel is def on my list, where did you get it?
Old May 6th, 2014, 09:17 PM
Bill Larson
Bill Larson
MuddUK 4x4
------ Follow up post added May 6th, 2014 08:21 PM ------
They are great to work with and it's worth the price...when he was working on my cross member Matt went to open the tire carrier and felt something off with it...I thought it was perfect...next thing you know he's milling down a piece of metal...he knows his stuff.
Old May 7th, 2014, 12:38 PM
Bill Larson
Bill Larson
Finally installed the new face plate this morning with a dual Blue Sea USB in place of the cigar lighter. Replaced all of the 5 Bar...what a pain that was...replaced the head lights....paint touch up.
ID:	94357   Click image for larger version
Old May 9th, 2014, 09:51 AM
Bill Larson
Bill Larson
New Transmission lines and trans oil cooler going in today! Also replacing the fuel fuller neck and dropping the tank tonight for something to do! lol...The little splash back metal flap on the filler mouth broke...try yanking the fuel nozzle out when the broken spring is caught...not fun! Thank goodness I typically have tools in the truck!
Old May 11th, 2014, 09:46 PM
Bill Larson
Bill Larson
Installed the Mudd UK Sand Tracks with the flip down (picnic table) option...also effective against repelling Zombie side entry. Oh can't forget to mention...on this installation...measure 4 times...drill once and have a clear interior work area. I had to remove the Lasalle to do this...uh yeah...PIA!
ID:	94733   Click image for larger version
ID:	94735   Click image for larger version
ID:	94742   Click image for larger version
Old May 11th, 2014, 10:09 PM
Post a picture of the outside with it closed!
Old May 11th, 2014, 11:10 PM
Bill Larson
Bill Larson
I thought I had...there you go....still needs some tweaks and I have to do the other side. That will go quicker.
Old May 23rd, 2014, 09:45 PM
Bill Larson
Bill Larson
New Rubber (MT/R 285/75/16) and the new CTI courtesy of Briggs Custom Rovers.
ID:	95637   Click image for larger version
ID:	95639   Click image for larger version
Old October 5th, 2014, 01:44 PM
Alaskantinbender's Avatar
Alaskantinbender
jim
63 series 2A 109 3 door
Very nice job, an inspiration for sure.
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Help! Bad noise out of right rear!! P1CR Defender Technical Discussions 14 March 2nd, 2004 09:29 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
