Back Rack Prototype Fabrication - Defender Source
Old June 15th, 2009, 10:01 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
In an effort to continuously improve on existing Rover stuff or design new accessories, I am developing what I call the xxxx Rack. It's a rack that sits on top of the tub rails between the cage and allows for the mounting of a spare tire, jerry cans, a Hi-Lift, or other accessories. It's modular, so you can add in several more jerry cans, or use it to carry a gear basket or other accessories.
The design allows for the centering, or offsetting of the spare tire, depending on gear needs. The jerry can holders can be added as needed. Without speakers boxes, you can carry 3 jerry cans with 33" spare. Jerry can holders are held in with quick release pins, and the strap that holds the can in the holder utilizes those same pins (not pictured). I also designed it to fit up to a 35" spare.
How does the rack mount? Right now it uses the two small captured nut mounts on either side that the top uses - this allows the rack to be used inside a hard top if needed. Obviuosly these are not strong enough, so the user would need to drill mounting holes and bolt it in as neccessary.
I have not worked pricing yet, but the rack will be in the $200 range, with each jerry can holder being about $40. Once pricing is set, I'll post it officially in the Vendors Section. I don't see a huge market for them, but several customers asked about this type of option.
More pics to follow...
ID:	20027   Click image for larger version
ID:	20029   Click image for larger version
Semper Fi!
Old June 22nd, 2009, 06:43 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
That is brilliant, nice job!
If I convert my 110 to a double cab I will be giving you a call.
ac, rack
NEW Wolf Fabrication X-Mod Roof Rack Wolf Fabrication The Vendors Loft 29 January 9th, 2013 09:52 AM
Custom Roof Rack Fabrication Wolf Fabrication Smaller Projects 49 May 18th, 2009 03:12 PM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
FAST BACK Bows and fabrication paulb Defender Technical Discussions 0 March 23rd, 2005 04:02 PM
