Aux Heat thoughts - Defender Source
Old October 12th, 2016, 01:20 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Aux Heat thoughts
I need more heat. For you northerners, or desert rats (cold at night) there is a new player in the diesel heater market.
The Planar 2D-12 is becoming popular here. NorCal van hippies discovered this in the US a while back. Planar are under $500 on Amazon. Russian made, so you know they stole a good design!
• Heat output; kW (BTU): 0.8-1.8.0 (2,700-6,200)
• Fuel consumption; l/h (gal/h): 0.10-0.24 (0.03-0.06)
• Nominal supply voltage; V: 12 or 24
• Power consumption; W (A): 10-29 (0.8-2.42)
• Air flow rate; m3/h: 34-75
• Weight; kg: 7.0
• L x D x H; mm: 324 x 118 x 119
• Operating modes: Temperature/Power
Decent BTU output. Comes with control, hook up hardware, etc.
So I am thinking of the Nakatanenga under console/cubby frame. Good airflow in and out (duct the outputs), raises console to useable height, adds capability for other accessories.
All I know is it is getting cold AF here in Germany already, and the Mr.Buddy does not seem yhe wisest choice for a moving vehicle.
Thoughts? (besides "don't be a pussy, man up..")
KGH - “Stinky LR diesel” Defender Snob
Old October 12th, 2016, 06:57 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Really curious about the name Tenega cubby frame. How much of that drops into the seat box over the trans? Do you happen to know the dimensions?
Old October 12th, 2016, 11:05 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Interesting blog showing use of the nagatenaga (sp?) box for just such an install.
http://www.adventure-continued.com/webasto-air-heater/
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old October 12th, 2016, 12:20 PM
KGH's Avatar
KGH
Real Name
Good catch. The Webasto and Eberspacher (Espar in US) are 3x the price of the Planar.
Too bad he did not post a follow up - good or bad.
Nakatanenga.de website has the dimensions.
Old October 12th, 2016, 12:46 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I'm guessing from your local that you have a diesel. I'm also assuming it produces less heat than the NAS V8's do.
Maybe a combination of a radiator Muff, and a Drop Curtain behind the second row (or even front row if you don't really carry passengers in the back) would be enough?
The NAS V8 seems to put out a good amount of heat, and using a drop curtain behind the seats of a 90 can make it pretty toasty..
http://www.defendersource.com/forum/...tml#post480152
http://www.defendersource.com/forum/...ble-47722.html
~Scott T.
'95 D-90 ST - AA Yellow
Old October 12th, 2016, 01:16 PM
ontheway's Avatar
ontheway
Dave
I'm considering this or a webasto because my commute isn't long enough to heat the coolant and get heat. However, in sub zero temps it's a long enough commute that I need heat! A forced air heater is the best solution in this case. A drop curtain, blower upgrade, etc won't help.
Old October 12th, 2016, 01:50 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I'd go aux heater in a heartbeat, it also allows you to run it when you run into a store or I am sure would aid in defrosting a vehicle (I imagine it would be pretty easy to hook into a remote)
Old October 12th, 2016, 02:13 PM
KGH's Avatar
KGH
Real Name
Look into Webasto coolant heaters. Can get remote or phone app. Dial-a-toasty ride.
Old October 12th, 2016, 02:36 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
it is quite a bit cheaper on Amazon than on their website $460 https://www.amazon.com/gp/offer-list...6297113&sr=8-5
Old October 12th, 2016, 02:51 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
The beauty of any of these fuel fired heaters are they can run when the engine is not running.
I am working on a center console that contains a small heater AC combo unit that will direct hot or cold air to the center and rear passengers.
This unit requires the engine to be running to supply hot coolant or AC refrigerant to operate.
RDavisinVA
Old October 12th, 2016, 03:09 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Is this in the same queue as the MERC hydraulic engine mounts for a 300 TDI
Old October 12th, 2016, 03:26 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
You know it and 200TDI as well.
Seems like every time I get a chance to work on one of these projects, something breaks and attention has to shift.
Weekend before last, set up a 145 watt solar panel and was thinking about how to wire it up for camping use.
I actually said out loud "it is so nice to not be fixing a broken Land Rover".
The very next second my son called with a stranded 110.
Threw a tool bag in the other 110 and headed in his direction.
3 hours later it was dark and had to put the panel away, but the 110 our son was driving was up and running.
SSDD.
RDavisinVA
Old October 12th, 2016, 07:28 PM
flananuts
Matthew
I thought I'd add for those planning on doing a webasto install, I was having a heck of a time finding proper accessories including vents, tees, and duct here in the US. I found suremarine.com which had everything I needed at reasonable pricing from one place. Thought I'd pass it along.
Old October 12th, 2016, 08:17 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Super helpful, thanks for posting that!
Old October 12th, 2016, 08:42 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Interesting, when do you expect to have details?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old October 18th, 2016, 09:09 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
With summer over need to get time to get mine installed, was looking to source a few parts and while on ebay found these ... thought I would share
$140 for a rebuilt Airtop ... granted these are older models, but so are our trucks
Webasto Airtop 2000s D Heater PDC0063 01002665 9014839C | eBay
Old October 18th, 2016, 09:21 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Just mount them under the second row seat on a 110. Works fine.
Old October 18th, 2016, 01:08 PM
wow...thanks guys...this info is great!
Old October 18th, 2016, 02:09 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Will these work for any engine? Looks like these are electric units.
------ Follow up post added October 18th, 2016 01:12 PM ------
Will these work for any engine, I have a 3.5 V8? Looks like these are electric units.
1983 ROW D110
1970 Series III (Parting out)
Old October 18th, 2016, 02:59 PM
wanabewheelin
Michael Sword
They are for diesel, the company selling them is Schneider Trucks Dot Com, pull them out of semi's and refurbish. They are designed for over night sleeping so they don't have to run the semi all night to stay warm. Runs off diesel and the battery. They do make gas versions I believe, but these are all going to be diesel I would guess. Cheers.
ht
Aux Heater? NASD90 Defender Technical Discussions 59 December 21st, 2010 12:24 PM
Aux tank and LR winch bumper Jase For Sale - Parts 10 July 1st, 2005 06:38 PM
Aux Rocker switch - OEM Kimos Defender Technical Discussions 3 December 1st, 2004 09:52 AM
Rover-X Aux Fuel Tank and kit 4Sale bigrenna For Sale - Parts 2 November 18th, 2004 05:35 PM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
