Attaching a Rear License Plate - Defender Source
Join the Defender Source Community Today
Old September 7th, 2016, 06:42 PM
kurtisblo's Avatar
kurtisblo
Kurt
1991 Defender 110, LHD 200TDI
Hi Everyone. Looking for some direction on the best way to attach a license plate. My truck currently does not have any holes. One friend suggested you simply drill holes in the body and use screws to attach. With or without a frame. Anyone have any specific recommendations? Drill bit size, screw size, screw type? Here is a photo. Thanks
Also, any ideas for the front plate is appreciated
ID:	157159   Click image for larger version
Old September 7th, 2016, 06:44 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I would drill and install rivnuts and bolt into those.
Old September 7th, 2016, 06:48 PM
lithium1330's Avatar
lithium1330
'97 D90 SW NAS
I used plastic expansion rivets to hold the rear plate on.
I also used plastic washers between the plate and body panel to keep the plate off the paint.
Btw, very clean truck! Need to have you & your truck come out to one of the Bay Area gtg's!
Old September 7th, 2016, 06:54 PM
Rivnuts for sure. You can buy a kit at Harbor Freight for cheap.
Old September 7th, 2016, 07:12 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Rivnuts suck for many things but they are perfect for this application.
Not much stress from a plate.
Rent my
Old September 7th, 2016, 07:17 PM
K2atlanta's Avatar
K2atlanta
Kevin
1983/Defender110
I used a bracket like this that I screwed to existing holes from the UK plate. I feel your hesitation to screwing or riveting anything to that beautiful finish.
https://www.amazon.com/gp/aw/d/B0003...XGL&ref=plSrch
Old September 7th, 2016, 07:24 PM
I believe there's a standard defender plate hole pattern.
Or you can go with jeep-style spare tire carrier mounted plate holders, if you don't want to drill a hole.
Old September 7th, 2016, 08:52 PM
If you use rivnuts, use plastic screws. Metal screws seize in them and they are a pain to drill out.
Old September 7th, 2016, 08:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
Double sided tape
Old September 7th, 2016, 10:14 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Originally Posted by bjf View Post
Double sided tape
This, buy the dark gray 3M double sided tape, it will never come off again.
Old September 7th, 2016, 10:28 PM
bjf's Avatar
bjf
barry f
94 ST #395
It's how they do it for euro plates hence no holes
Old September 7th, 2016, 10:35 PM
1/4 20 rivet nuts/rivnuts. Use anti seize on the screws when you mount your plate and you will never have an issue.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old September 8th, 2016, 02:21 AM
kurtisblo's Avatar
kurtisblo
Kurt
Originally Posted by lithium1330 View Post
I used plastic expansion rivets to hold the rear plate on. I also used plastic washers between the plate and body panel to keep the plate off the paint. Btw, very clean truck! Need to have you & your truck come out to one of the Bay Area gtg's!
thanks. Can you share the exact product you used? I'm embarrassed to say I don't really know how rivnuts work. You drill a hole, then using the riv, tool, you drive a threaded sleeve into the hole that you can then bolt to? About right? Can anyone send links to specific products that I should use for the plastic rivs and a riv tool? Is this the tape people use?
I'm thinking I might do riv in the read and tape in front
Old September 8th, 2016, 02:31 AM
lithium1330
'97 D90 SW NAS
I use something like this. You can pick them up at Home Depot or Lowes, along with the plastic washers. You'll want to get one that's long enough to go through the plate, plastic washer then the body panel.
I prefer these (over metal nuts & bolts or screws) since these are plastic... and removable by pulling that center pin back out if you ever need to remove the plate for whatever reason.
Edit: not sure how well double-sided tape do with U.S. plates. Unlike Euro plates (#'s printed on a flat piece of plexiglass/lexan), the U.S. plate backing is not-so-smooth metal, with a sharp/ridged surround, and recessed numbers/letters.
Old September 8th, 2016, 02:40 AM
kurtisblo's Avatar
kurtisblo
Kurt
how hard is it to get the tape off if I use it temporarily before using riv nuts?
------ Follow up post added September 8th, 2016 12:42 AM ------
thanks. how hard is it to remove the tape if I use it temporarily until I put in rivnuts?
Old September 8th, 2016, 02:59 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
I used the double sided 3m tape and haven't had any issues, but I have also not driven my truck in close to year, BUT they have held on while sitting in a dusty barn!
I'll probably end up doing a rivnut solution, eventually...
Old September 8th, 2016, 03:51 AM
Auto parts stores sell packets of four plastic rivet nuts and stainless screws specifically to attach plates.
Let's not overthink this!
Old September 8th, 2016, 04:26 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
3M it. Why drill any holes? It's perfect as is. Sure, if there were already some holes, or they were in the wrong place, then what's one more set of holes so long as they aren't visible. But this is different. That's a beautiful truck and those locations are unblemished. Maybe you'll relocate your plates in the future. Tape would allow that. This stuff is strong and exterior grade. It'll hold forever. You can practically build with it. $6 at Home Depot. 3M extreme mounting tape. It can be removed, but you have to rotate the fixture/license plate frame to start the peel. Then any residual can be rubbed off. Easy peasy and not overthought.
Old September 8th, 2016, 07:30 AM
Another vote for double sided tape
Old September 8th, 2016, 08:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
Exactly
ac, license plate
New Rear License plate and rear step lamp LenB For Sale - Parts 0 May 10th, 2016 11:30 PM
Wanted: Rear License Plate Holder for RRC signalMTB Wanted 5 April 30th, 2016 10:15 AM
Attaching License Plate on NAS 90 SW dendrite Defender Technical Discussions 23 June 4th, 2015 08:02 PM
Rear License Plate Light Wiring Alex D90 Smaller Projects 2 November 2nd, 2008 10:27 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 07:54 PM
