Attaching a Rear License Plate - Page 3 - Defender Source
Old September 15th, 2016, 10:29 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You can even get the rubber ones.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 17th, 2017, 04:26 PM
Al Blue4.6l's Avatar
Al Blue4.6l
Allen
2006 LR3
Bumping this for future readers - I ordered this on amazon and it worked great using the two ROW stock holes:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Just needed a couple of nuts/bolts/washers to mount it to the two stock holes and I bought a couple of short screws to mount the plate to the bracket
Old February 17th, 2017, 06:03 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Originally Posted by bjf View Post
It's how they do it for euro plates hence no holes
From what I have seen in Europe, the method is hold the plate where you want it, take any screw, zap it in. Not the best method, I agree. When we bought our CPO Puma from the dealer, I watched the guy do it. It is crooked.
Have seen a lot of Defenders here, none ever with double sided tape.
KGH - Defender Snob
Old February 17th, 2017, 06:40 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Best post. Ever.
Originally Posted by rijosho View Post
I think they sell that tape in different widths. What is the ideal width of tape to use for a license plate? 1/4"? 1/2"? 1"? And should it be boxed along the perimeter or an X across the middle back of the plate? You said it's strong enough to build with - can it also hold a tire carrier if I haven't drilled holes for one yet? And should the front license plate go in the middle, biased toward the driver or passenger (and if so how much?).
Old February 18th, 2017, 09:21 AM
Matt_110's Avatar
Matt_110
Matt
110
My UK plates were held on with double sided tape. Strong as nails...almost broke the plate in half taking them off.
Thanks for the Amazon link. That looks like a great option
1987 110, 2.8TGV, ZF Auto
Old February 18th, 2017, 10:47 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by rdavisinva View Post
I have always used pop rivets with a stainless washer.
Same size self sealing as the ones used on the body.
Easy enough to drill if you need to remove the plate.
Fastest and easiest way in my opinion.
I am not a fan of rivnuts.
The way we do it as well...
Hard to have some ne'er-do-well casually remove the plate without a drill.
Old February 20th, 2017, 07:21 AM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Originally Posted by PabloCocito View Post
This, buy the dark gray 3M double sided tape, it will never come off again.
That is how I did mine and no problems for over two years.
Old February 20th, 2017, 10:49 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
The problem with tape (from someone who has had to remove a dozen of UK plates that were taped on) is that the tape does not always want to let go when it's time and paint panels have been worse for it.
Old February 20th, 2017, 02:09 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
True. That would be a concern. In full disclosure, What I actually did was put black vinyl wrap over the euro plate and then stuck my TN plate to that.
Old February 20th, 2017, 02:22 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
It's simply a matter of thinking ahead. Tape may be the solution for right now, but what's it going to do to you down the road? Always think ahead.....
ac, license plate
New Rear License plate and rear step lamp LenB For Sale - Parts 0 May 11th, 2016 12:30 AM
Wanted: Rear License Plate Holder for RRC signalMTB Wanted 5 April 30th, 2016 11:15 AM
Attaching License Plate on NAS 90 SW dendrite Defender Technical Discussions 23 June 4th, 2015 09:02 PM
Rear License Plate Light Wiring Alex D90 Smaller Projects 2 November 2nd, 2008 11:27 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
