Attaching a Rear License Plate - Page 2 - Defender Source
Old September 8th, 2016, 09:38 AM
Originally Posted by D90Overkill View Post
3M it. Why drill any holes? It's perfect as is. Sure, if there were already some holes, or they were in the wrong place, then what's one more set of holes so long as they aren't visible. But this is different. That's a beautiful truck and those locations are unblemished. Maybe you'll relocate your plates in the future. Tape would allow that. This stuff is strong and exterior grade. It'll hold forever. You can practically build with it. $6 at Home Depot. 3M extreme mounting tape. It can be removed, but you have to rotate the fixture/license plate frame to start the peel. Then any residual can be rubbed off. Easy peasy and not overthought.
I think they sell that tape in different widths. What is the ideal width of tape to use for a license plate? 1/4"? 1/2"? 1"? And should it be boxed along the perimeter or an X across the middle back of the plate? You said it's strong enough to build with - can it also hold a tire carrier if I haven't drilled holes for one yet? And should the front license plate go in the middle, biased toward the driver or passenger (and if so how much?).
Old September 8th, 2016, 09:55 AM
bjf's Avatar
bjf
barry f
94 ST #395
Amazing
Old September 8th, 2016, 11:53 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Tape!
My BB badge that weighs many times what the license plate weighs, has been stuck on with that 3M red tape for a couple of years now.
Yes, the license plate is attached with plastic screws and there are rubber washers behind it to keep it off the paint.
Name:	BB D90 SW.jpg
Old September 8th, 2016, 02:02 PM
bjf's Avatar
bjf
barry f
94 ST #395
What about dry wall screws. I think they will hold it on for the long haul.
Old September 8th, 2016, 03:21 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I have always used pop rivets with a stainless washer.
Same size self sealing as the ones used on the body.
Easy enough to drill if you need to remove the plate.
Fastest and easiest way in my opinion.
I am not a fan of rivnuts.
RDavisinVA
Old September 8th, 2016, 03:49 PM
Ben01
Ben
Defender
I drill into the plate and use whatever holes may be in the truck already
Old September 8th, 2016, 04:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
OP doesn't have holes in the truck.
Old September 8th, 2016, 05:06 PM
Ben01
Ben
Defender
go for tape
Old September 8th, 2016, 05:10 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I just drilled stainless screws into the metal and used rubber washers to separate the plate from the body. It's not like license plates are changing size or you will put it somewhere else one day.
Old September 8th, 2016, 06:24 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Tape is a bad investment.
RDavisinVA
Old September 8th, 2016, 09:23 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Kurt, you may want to look at a proper plate holder.
DRM000011 is the Genuine LR part number for a plate holder. Should run you about $35 or so. 2 rivnuts in the back, hold it in and you have a holder that keeps the plate from vibrating and scraping off that nice fresh paint. Also lets you attach the plate to the frame with 4 screws.
Neat, tidy and secure.
Old September 8th, 2016, 09:47 PM
The factory set up on NAS trucks is four rivnuts and there is a 1/4 inch rubber "plate" carved with a Land Rover oval that you can fix between the license plate and the panel. With plastic screws this is pretty great.
Old September 10th, 2016, 01:46 PM
kurtisblo's Avatar
kurtisblo
Kurt
1991 Defender 110, LHD 200TDI
Big thanks for all the replies. I think I'll use the tape temporarily just to get the plates on quickly and see how it goes. If I get motivated i may for for the more sturdy and permanent solution of using the backer plate and rivnuts. Much appreciated all.
Old September 10th, 2016, 02:03 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Why are you not a fan of rivnuts?
Old September 10th, 2016, 02:04 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Good move, sir.
Haha. They actually don't. Just 1" widths I'm afraid. And I know you're just messing with me, but to be honest, I'd do a perimeter tape job (seam to seam) to both hold and act as a water barrier protecting the "x" in the middle of the plate that would hold the plate indefinitely. Overkill is my thing ;-)
"Barry is correct!"
Old September 14th, 2016, 07:29 PM
kurtisblo's Avatar
kurtisblo
Kurt
Another rookie question. If i do end up doing rivnuts, I assume I should use aluminum and not steel so that it is similar metals?
Old September 14th, 2016, 07:42 PM
Stock are steel. I have not seen aluminium rivnuts. Maybe they exist.
Old September 14th, 2016, 07:47 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
a
Aluminum riv nuts are certainly around, I just used a wack of them.
That's definitely what I would use to avoid any corrosion issues.
Old September 14th, 2016, 08:01 PM
D90Overkill
David Frank
1995 ST #2615
Alu is available at ace, osh, and of course, fastenal. If you can't find any easily, I'll pick some up and mail them to you.
"Barry is correct!"
Old September 15th, 2016, 09:56 AM
kurtisblo's Avatar
kurtisblo
Kurt
thanks! I can find some online I'm sure.
Btw, I went to Osh, O'Riley and Home Depot and NONE of them had rivnuts or even knew what I was talking about! Amazon is my friend.
ac, license plate
New Rear License plate and rear step lamp LenB For Sale - Parts 0 May 11th, 2016 12:30 AM
Wanted: Rear License Plate Holder for RRC signalMTB Wanted 5 April 30th, 2016 11:15 AM
Attaching License Plate on NAS 90 SW dendrite Defender Technical Discussions 23 June 4th, 2015 09:02 PM
Rear License Plate Light Wiring Alex D90 Smaller Projects 2 November 2nd, 2008 11:27 PM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
