ARB Question - Defender Source
Old June 6th, 2010, 05:40 PM
RoverRideAlong
Rob Cleveland
95/DI
ARB Question
Excuse my ignorance, but I am in the process of re-installing my rear third member after replacing the pinion bearings and carrier bearings in the ARB. I hooked up the air line to the third member before installing it back into the axle housing to check for leaks and have a slight flow of air coming from the seal housing assembly until the locker is rotated in which it stops. I didn't know if that was normal or if that seal housing o-ring is faulty and causing the leak.
This is a learning process for me so thanks in advance.
Rob
Old June 7th, 2010, 05:15 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
ARB has constantly had issues with those o-rings, and depending on what year your locker is you could have one one of the older style seals that are prone to failure. Anytime I take an ARB out to do the bearings I put in a new o-ring.
I just installed two brand new ARBs and noticed the new style o-rings are much better - they have two sealing "lips" instead of being just an "o ring."
Good luck!
Semper Fi!
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB Bull Bar for 97 D-90 Seriesman Defender Technical Discussions 4 October 4th, 2004 10:00 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
ARB question rover4x4 Defender Technical Discussions 3 February 5th, 2004 06:17 PM
Doh! ARB 9000i Mounting question dnewman9 Defender Technical Discussions 14 February 5th, 2004 01:11 PM
