Arb Limb Riser Tabs - Defender Source
Old June 28th, 2010, 11:48 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Arb Limb Riser Tabs
Probably the smallest project in the small project category:
I'm thinking about having someone make a pair of steel tabs that you can weld onto the Arb bumper so that you can hook up your limb risers to these tabs. Any suggestions of how and where to make these are appreciated. I'm thinking water jet cut?
Old June 29th, 2010, 12:30 AM
Seems excessive to waterjet. 3/16ths x 2in plate cut and rounded at the top and a drill would work.
Old June 29th, 2010, 06:53 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Or just go to Ballistic Fab or any other fab place online and order a pair dirt cheap
Semper Fi!
Old June 29th, 2010, 09:12 AM
Dredd
Harlan Boone
ARB is powdercoated. Make sure you protect the welded area after the work is done or you'll end up chasing rust travelling under the powdercoating from the compromised area.
HB
Old June 29th, 2010, 09:16 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Or just get these:
http://www.roverparts.com/Parts/ARB3590.cfm
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old June 29th, 2010, 10:06 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Excellent! Thanks Jonathan! I will use the ballistic fab guys.
My Arb is going to be removed and re-powder coated in a few years. Meanwhile I will rustproof that area.
Eric, I considered the antenna mounts but I am looking for a cleaner and more solid approach.
Thanks!
Old June 29th, 2010, 10:37 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks!
Probably overkill, but I can make you some clamp on ones for roughly $80. That way you won't kill the powdercoat.
Semper Fi!
Old June 29th, 2010, 11:39 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I appreciate the offer Jonathan but my Arb is already abused. There were holes drilled for curt mfg hooks courtesy of the previous owner, rust included. The tow hook loops are also rusty and the powdercoat is old and tired so I'm going to touch things up for now and repowder coat it in a few years when I redo the body paint.
If their standard HD loops won't work I will get a quote for my 3D.
Thanks again for the tip!
Old June 29th, 2010, 03:13 PM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
Here ya go... 10.99 for 2 , just cut half the tube circle out and weld them on.. laser cut and pretty..
http://www.ballisticfabrication.com/...41_p_1434.html
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old June 29th, 2010, 03:54 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That might work. The ARB tube is 1.9". I might be able to use the 2" they have... or I could get the 1.75" and grind it out.
I'm also waiting for the quote on the 3D I sent to them.
Old June 29th, 2010, 04:22 PM
Didn't every defender come with four those as tie downs from the boat ride from the motherland? Mine did.
Old June 29th, 2010, 04:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Scott.
This is for the top tube of the ARB bumper. Arb didn't come stock to my knowledge. This is for attaching your Limb Risers (Branch Deflectors). I will post pictures ones its welded on.
Old June 29th, 2010, 05:39 PM
The link that Lane posted, it what I was referring too. They look just like the tied down rings that were on the trucks when they were shipped over.
On my SG brush guard, I used a small set of Pipe hangers with a small piece of rubber underneath them. They cost about $3.00.
Old June 29th, 2010, 06:54 PM
IIRC I used some rubber lined strap on my disco when I did this. I still have all that crap in a box in the attic. Since I am brush guard free for a few years, I just let them sit.
Old July 1st, 2010, 08:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ballistic fab is cutting a custom pair for me. Same price as the retail ones they sell.
Old July 1st, 2010, 09:40 PM
mightymg's Avatar
mightymg
Lane Farka
Those guys rock, ive bought a ton of shit from them...
project whore!
95 RRC LWB-- DD
Limb riser mount tabs for new style Hannibal LenB Smaller Projects 2 July 27th, 2007 09:56 AM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
installing Warn XD9000i winch in ARB bumper eric_besore Defender Technical Discussions 11 March 28th, 2006 09:36 PM
ARB vs. Detroit's souza Defender Technical Discussions 34 February 7th, 2004 01:16 AM
Limb Riser Fabrication Peter Defender Technical Discussions 2 October 21st, 2003 10:34 PM
