ARB compressor location? - Defender Source
Old April 10th, 2016, 10:38 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I have for the last time spent an hour using a plug in cigeratte lighter air pump to air my tires back up. I am wanting to install a arb compressor. My question is where have most of you put yours? I am later planning to install lockers so that has to fall into my plan too. Include pictures too.
Old April 10th, 2016, 10:57 PM
Hopefully you got the big one as the regular one is really slow. There are better bangs for the buck if doing an electric compressor.
Old April 11th, 2016, 09:57 AM
What compressor do you recommend?
Old April 11th, 2016, 10:15 AM
I have the ARB single - it works but is kinda slow but gets the job done- i would recommend getting either the ARB Twin or a York.
however the single ARB fits nicely in the passenger side cubby box along with the ECU on A 95 NAS 90 with room left over for the hose and other gear.
I do not have an AMP for the stereo as well. so its just a blank space.
or you could fit it behind the pass seat (Single or twin) or in a troy box in the rear.. lots of possibilities
95' D90 - daily driver..
Old April 11th, 2016, 11:02 AM
Viair 400. It does look like their prices have gone up and the ARB has come down, so it is not as cut and dry as it once was.
Old April 11th, 2016, 06:23 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
under the passenger seat
good luck with your search
Old April 11th, 2016, 06:58 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
Under my left wing, mounted on to of the inner fender next to the power panel, beneath the blank off plate. Mounted it on a piece of angle with some spacers so it would remain level.
If at first you don't succeed, skydiving is not for you.
Old April 14th, 2016, 07:19 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
Thought I'd throw this into the mix. I made this larger storage area to accommodate the twin pump, tank and manifold for locker solenoid's. No deeper than stock just longer. Compressor filters went out back of the box. Easy to clean/pop off from underneath. The output from the tank goes out the back and down to the frame for distribution to front rt headlight bezel. I bent up 1/2" stainless for more storage capacity. I can air up 4 tires before others with the smaller pumps can air back up one.
I made patterns and templates by the way. I used .032 5052 aluminum and worked just fine. .040 would work real well too. I'm always fussy about weight.
compressor
Pic's needed - Recovery point location on ARB bumpers rlynch356 Defender Technical Discussions 14 October 20th, 2016 08:35 AM
Best ARB Compressor installation location? silverlight Defender Technical Discussions 34 February 16th, 2015 10:19 PM
ARB Air Pump mounting Location????? jetmech Defender Technical Discussions 7 December 18th, 2009 09:06 PM
Location for ARB Compressor Seriesman Defender Technical Discussions 10 August 15th, 2004 04:09 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
