Any ideas for a cup holder insert in OEM center cubby? (& 1 other question) - Defender Source
Old April 7th, 2013, 03:14 PM
silverlight's Avatar
silverlight
Geoff
1993 Defender 110 NAS
Been hunting around online for an insert of some kind I could use for 2x drink holders in the open part of the box in the front of the OEM cubby. I don't want to change out the OEM unit, so looking for a solution that might work. The measurements are 9.5" x 4.75". Not sure if any vendors make one to fit, didn't find one online. Also totally open to a more creative solution. thanks for any thoughts!
Another probably very easy one and borderline dumb question. I have an OEM light swtich I'm planning to use to replace a 3rd party switch I'm using temporarily for fog lights. I couldn't find a harness / 4 pin connector / pigtail w wires, any suggestions for where I could find one that fits?
Many thanks!!
Old April 7th, 2013, 03:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Your cubby is missing the factory cup holder that goes there.
Old April 7th, 2013, 04:03 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I got one from lucky 8. I can measure it later tonight.
Old April 7th, 2013, 04:19 PM
silverlight
Geoff
Thank you! both great leads. the Lucky8 website is partially down, so can call them. In looking for the OEM insert, I came across a Tuffy drink holder which should also fit in there fine as well, little extra room but that's no problem.
Old April 7th, 2013, 07:46 PM
silverlight
Geoff
Since we are talking about the high quality factory console, you could make one out of MDF, some vinyl (pleather, if you will) and a hole saw.
-Jeff
Old April 8th, 2013, 08:24 PM
Explorer0863's Avatar
Explorer0863
Tony Q
1957 Series I V8
I installed 2 of these in my old Landy. They can be closed when not in use. About $10 each at West Marine.
Old April 8th, 2013, 10:23 PM
silverlight
Geoff
Thank you, another good solution. Found the same ones (or very similar) on amazon prime so will give a set of them a shot. Appreciate the suggestions!
Old April 8th, 2013, 10:44 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Many thanks!!
Give Josh at British Wiring a call. Send him that photo and he should be able to help you locate the plug.
Old April 9th, 2013, 12:03 AM
silverlight
Geoff
Awesome, thanks Chris!
oem
Tuffey center console cup holder needed SafariHP Wanted 1 July 28th, 2012 08:32 PM
FS - LR OEM Center Console w/radio - 1995 jam90 For Sale - Parts 2 January 19th, 2006 11:31 PM
1997 Cubby Box Insert sigma Wanted 0 May 11th, 2005 05:13 PM
Center console cubby box PT94D90 For Sale - Parts 1 February 8th, 2004 10:03 PM
cup holder s***s ! artm Defender Technical Discussions 10 November 12th, 2003 01:07 PM
