another way to do rear headrests - Defender Source
Old May 14th, 2013, 01:09 PM
jack SF
jack baran
95 ST yellow
hi. these are some photos of my rear headrests. it was easy. this is for a 90, I don't know how the 110 seats are made.
basically the backrest is a square. I cut out a couple of inches so that I can insert a vertical channel for headrest to slide up and down in. welded everything in and powder coated.
backrest frame is very flimsy and this made it a little stiffer.
the channel I used was just scrap from a range rover seat track. you are gone have to bring in your headrest to a metal supplier and find a channel that fits it.
the first photo is bottom of frame and 2 others are at top.
wiki
Rear diff replacement options cgalpin Defender Technical Discussions 20 July 14th, 2007 01:21 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
