The next project from Wolf's Micro Garage is a 1/10 scale D90 ST for a D90 Source Member. This build is based on the Gelande D90 kit and will be attempt to be a true NAS D90 ST with NAS ST rear cage, soft top (hopefully), and front A hoop.
This is truly an amazing, high quality kit. Everything is milled aluminum, tight tolerances, well thought out. This kit is more for the casual driver and not for thrashing on the rocks like the Axial SCX-10 kits.
Transmission
Nice milled aluminum chassis pieces
Frame assembled
Frame with tranny installed
Tcase
Transfer case mated to the tranny and mounted.
Nice thick aluminum rear crossmember
Frame pieces nicely packaged.
Front axle. Nice steel reproduction with removable 3rds.
Rear axle.
All the trailing arms, links, and steering rods.
Quality shocks
Rear suspension
Transmission
Frame assembled
Tcase
Rear axle.
Quality shocks
Rear suspension
