Another 1/10 Scale Rover Build - Page 2 - Defender Source
Old October 30th, 2013, 04:32 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Done for the most part besides adding LED headlights and tail lights.
The owner plans on contacting Badger for some soft top scraps to build a true soft top
ID:	83115   Click image for larger version
Semper Fi!
Old October 30th, 2013, 07:38 AM
I or anyone else who has a Badger top and took out the extra fabric from the window section that he leaves in for delivery probably have some leftover fabric scraps.
Old October 30th, 2013, 09:32 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Wouldn't the badger canvas be too thick for that small of an application?
Old October 30th, 2013, 11:46 AM
is that a TD5 dash or mud-uk console?
Old October 30th, 2013, 02:43 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I was thinking of building an Axial kit has anyone built one? Or is there something better
Legend in My Own Mind.
Old October 30th, 2013, 03:08 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I have the original Gelande. Love it.
RC4WD.com
MUDSUX
Old October 30th, 2013, 04:21 PM
Wolf Fabrication
Sterling Archer
'08 D3
I've built several of both. Both have their pluses and minuses.
Axial:
Cons: Almost all plastic, incorrect wheelbase. 90 Body mounting can be tricky
Pros: Better suspension, quieter gears, you can thrash this one.
Gelande:
Cons: Loud gears, tolerances are a tad tight
Pros: most realistic frame, better drivetrain placement, almost all steel/aluminum parts, actually designed for the 90 body, some cool accessories, beadlock wheels.
Bottom line, the Gelande is a top quality kit, my only main gripe is that it is LOUD, and it's so nice it'd be hard to thrash on the trail. If you want a crawler, do the Axial kit.
Semper Fi!
Old October 30th, 2013, 04:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Can u put bigger tires on the d90 kits? They do look cool as hell
Old October 30th, 2013, 04:41 PM
What did you use for the cage?
Old October 30th, 2013, 04:44 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yes. You can drop the shocks down and adjust the springs down to get more lift.
I plan on building a 110 on 35s next.
------ Follow up post added October 31st, 2013 05:45 AM ------
I used lexan hollow tube. I'd use solid next time. With some heat it bends pretty easily. With the hollow stuff you could heat an entire section to get the oval shaped tubes if you really wanted.
Semper Fi!
Old October 30th, 2013, 05:02 PM
Ray_G's Avatar
Ray_G
Ray Gerber
RHD NAS spec truck? When you moving the steering wheel over to the correct side?
I gotta say, it looks fantastic-but it also makes me fear getting 3rd anything. Well, maybe not 3rd Radio.
r-
R
Old October 30th, 2013, 05:11 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Ray_G View Post
RHD NAS spec truck? When you moving the steering wheel over to the correct side? I gotta say, it looks fantastic-but it also makes me fear getting 3rd anything. Well, maybe not 3rd Radio. r- R
Sadly the body kit is RHD and it's a bitch to move over the steering wheel, but not impossible.
Oki is the best kept secret in the Corps!
Semper Fi!
Old October 30th, 2013, 06:08 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Let me know if there is a Disco kit...I may commission WolfFab minatures if you've got the time and access. A CT truck would be sweet.
I'll likely take your word on Oki; wouldn't work for my family situation and it looks like Quantico or a year on the bench before something else.
Old October 30th, 2013, 07:50 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by Wolf Fabrication View Post
Yes. You can drop the shocks down and adjust the springs down to get more lift. I plan on building a 110 on 35s next. ------ Follow up post added October 31st, 2013 05:45 AM ------ I used lexan hollow tube. I'd use solid next time. With some heat it bends pretty easily. With the hollow stuff you could heat an entire section to get the oval shaped tubes if you really wanted.
Cool I need to get one.
Old October 30th, 2013, 11:18 PM
Wolf Fabrication
Sterling Archer
'08 D3
You can get a Disco body here: http://www.kamtec.co.uk/index.php?pa...hk=1&Itemid=53
Steven from ONSLRS built a copy of his zebra striped Disco: http://www.scale4x4rc.org/forums/showthread.php?t=53677
Semper Fi!
Old November 14th, 2013, 06:30 AM
Wolf Fabrication
Sterling Archer
'08 D3
This truck has left Wolf's Micro Garage and boarded the cardboard transport for the east coast of the US. I hope the new owner will share photos of the truck in action.
Semper Fi!
1962 Land Rover Series IIa 88'' refurbished Mike Sandone For Sale - Vehicles 2 October 22nd, 2012 04:25 PM
Top Gear Tonight 10-18-10:The crew build motor homes on the backs of a Land Rover 110 KKilo23 Misc. Chit-Chat 6 October 19th, 2010 06:45 PM
2000 Range Rover 4.6 HSE for sale or trade for Defender treydub For Sale - Vehicles 6 February 28th, 2005 10:57 AM
1995 Range Rover 4.0 SE ember For Sale - Vehicles 2 January 24th, 2005 12:40 AM
The Greatest Rover Shop Ever Buckon37s Misc. Chit-Chat 2 December 22nd, 2004 01:00 PM
