Aluminum porn! - Page 2 - Defender Source
Old July 23rd, 2015, 08:14 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Very cool, it's making me rethink the way I'm doing mine.
I'm curious about the horizontal cross members, they look shallower than the original steel ones, is that just an illusion?
Old July 23rd, 2015, 08:26 AM
One minor thing - doesn't welding on both the horizontal and vertical crossmembers essentially lock the new tub floor into place, making it impossible to remove without cutting out the welds?
One of the advantages I found of the original steel crossmembers on the tub is that they were removable. This allowed the floor of the tub to be easily be removed by removing the rivets.
Old July 23rd, 2015, 09:04 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
You're right - they're shallower. The steel ribs grow about an inch in height once they're inboard of the body mounts on the chassis. That would have been a tedious piece to make so we ran a fixed height the entire way.
The floor assembly itself is still affixed to the tub sides using rivets, so removal would be similar and probably equally tedious, since the factory fasteners typically have to be cut out from the bottom in my experience. Though to be honest I can't think of a single good reason to remove the floor except for replacement...
-Ash
Geared Restoration Co.
352-572-3236
Old July 23rd, 2015, 09:16 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
-Ash
So are you going to run a spacer between the chassis and the new cross members to maintain the proper height?
Old July 23rd, 2015, 09:26 AM
Ash's Avatar
Ash
Ash Heller
No, the critical height is the 'short side' of the steel rib that sits on the chassis pads. That's how tall our aluminum ribs are all the way across. The added height on the steel rib is for strength, which isn't quite as important in our case since the whole assembly is built of considerably thicker material.
-Ash
EDIT: Here's a picture to help illustrate.
352-572-3236
Old July 23rd, 2015, 09:32 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
-Ash
Ah that makes sense.
Old July 23rd, 2015, 10:23 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Aluminum porn!
Well this certainly has me thinking, especially since I would need to make mods to the existing cross members for my new seats and to access the fuel sender on the tank.
Plus the one piece floor I had made is plenty thick to take some of the load of using aluminum cross members Click image for larger version
Thanks for posting this up. The timing is good!
aluminum
soft porn Uncle Douglas Misc. Chit-Chat 7 September 11th, 2008 08:48 PM
Little Rover Porn from Vacation Firefighter2904 Misc. Chit-Chat 5 September 6th, 2008 01:03 PM
Better than looking at porn Bozman Misc. Chit-Chat 20 June 13th, 2007 01:43 PM
Diesel Porn TDI Guy Misc. Chit-Chat 31 April 14th, 2006 03:37 PM
Rover Porn Roadsiderob Misc. Chit-Chat 3 November 24th, 2005 01:20 AM
