Alloy on 3rd door mount - Defender Source
Old February 19th, 2015, 11:27 AM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I picked up an extra alloy rim for the spare..the original steel with the original 27yo tire just doesn't cut it...I assume the studs are long enough, but would I need to use alloy nuts vs the steel nuts that are there now or the threads would be deeper in the holes and thus need alloy nuts...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 19th, 2015, 08:46 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
Spare tire
Can't you use the steel nuts on the back side of the alloy rim to set hoe deep it sits on the mount allowing you to use either nut on the front?
Old February 19th, 2015, 08:56 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
That may work...
Old February 19th, 2015, 10:13 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I recall the same issue when I tried to mount my alloy on the door. I tossed it in the back till I got a swing away carrier. Maybe you could get a spacer to bump it out some.
Old February 19th, 2015, 10:14 PM
You need alloy lug nuts and the thin little guys behind to get it in the right space.
mount, door, alloy
Quick Opinion Needed Powder Coat or Paint Alloy NAS 3rd Brake Light Bars SafariHP Misc. Chit-Chat 13 August 1st, 2011 08:12 PM
3rd brake light mount - Brush guard JWD Wanted 3 June 28th, 2010 01:03 AM
How to mount a Defender Alloy wheel on the Hood. Manimal Defender Technical Discussions 19 March 17th, 2009 11:32 PM
Bonnet Mount Spare Adapter for Alloy Wheels Manimal Wanted 0 March 14th, 2009 12:47 AM
WTB Wing Mount Pick Ax Mount NashvilleRover Wanted 1 September 13th, 2008 10:29 PM
