Air Conditioning Install - Defender Source
Old March 2nd, 2015, 01:03 PM
hpat's Avatar
hpat
Hayden
1989 110
I am a new proud owner of an '89 Defender 110, as well as this is my first post.
I am located in hot florida, and AC is a must for me. I am trying to figure out a neat looking way to install one. I have seen the kits designed for Defenders but they are expensive. Has anyone made a custom AC install or used one of the "vintage car ac" packages and made it work? Any help is appreciated. It will be installed on a 200 Td.
Old March 2nd, 2015, 01:06 PM
Yep ... there is a build thread where someone did this with all new parts for about $1000 ... it's there you just have to find it using the search features.
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
It can be done with enough ingenuity...the interior system is the easy part. Figuring out the correct combination of pulleys and brackets to hang the compressor on the 200 is going to be the tricky part, but it can be done. I have a 110 here in the shop that someone outfitted a universal muscle car system into. I don't think it looks as 'proper' as the model-specific kits out there, but that's not to say there isn't a non-Rover system out there that might look better.
-Ash
Geared Restoration Co.
352-572-3236
Old March 2nd, 2015, 01:15 PM
200TDI is super easy. Just put it in the stock location with the stock pulley and tensioner. The bracket to hold the compressor is a 1/2 hour construction project.
Mounting a condenser and running lines is a much bigger part of the job.
Old March 2nd, 2015, 01:31 PM
COJ142's Avatar
COJ142
Michael Giroux
1985 Defender 110 CSW RHD
Hayden - if ur rig is RHD I have something you might be interested in. It's the 200 TDI elite system that's basically factory look. It's two years old and in near perfect condition. I'm doing a left hand conversion so PM me if you'd like details. Pics in registry.
Old March 2nd, 2015, 01:38 PM
Vintage Air
Old March 2nd, 2015, 01:45 PM
rovertrader's Avatar
rovertrader
Dale
200 is an easy install- even building brackets and such. I have one here, so pics available if needed/wanted.
Old March 2nd, 2015, 04:30 PM
hpat's Avatar
hpat
Hayden
1989 110
I apologize, I made a mistake. The motor is a 2.5 TD not a 200 TDI. I know its under powered, but can't afford to change it right now
RHD 200di Custom Air Conditioning Install Wolf Fabrication Smaller Projects 23 May 1st, 2016 08:45 AM
Anyone install air conditioning? Wildduke Series Technical Discussions 13 May 11th, 2013 10:19 AM
Air conditioning scottheise Defender Technical Discussions 4 October 8th, 2004 10:13 AM
Electric Fans & Air Conditioning javelinadave Defender Technical Discussions 12 June 6th, 2004 08:44 AM
Air Conditioning azdefender Wanted 2 March 8th, 2004 01:41 AM
