Add toggle switches next to steering wheel - Defender Source
Old June 7th, 2016, 02:42 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Hi, I'm planning to add 2 add'l switches just left of the steering wheel (LHD).
I have a '97 NAS wagon with AC.
How do I get to the back of this part of the dashboard (with the 3 switches in picture below), so to run the wires and connect the switches?
I found this picture from ECR for reference:
Thanks!
Old June 7th, 2016, 09:25 AM
bjf's Avatar
bjf
barry f
94 ST #395
That section of the lower dash unscrews. Most the screws are visible but I think with ac one is inside a vent or speaker.
Old June 7th, 2016, 09:48 AM
Psuedo self-serving post, but if you're swapping out switches in that area you may want to consider going with a Carling upgrade if you want some switches that actually "work" when you need them to, are reliable, easy to use, and all around just function great:
ID:	151230   Click image for larger version
Old June 7th, 2016, 09:52 AM
jruti's Avatar
jruti
Jon Ruti
'94 D-90, #20
Correct, that particular part of the lower dash assembly unscrews independently. Believe the screw is located on the underside. Once unscrewed, gently push the panel up while simultaneously pulling out towards the door.
Exacto knife for the switch blanks. If you're using the genuine switches as pictures they do take a little massaging to get into the switch blanks.
Just a note as I did this: the genuine switches pictured are a tad awkward to switch on and off while driving. If I did it over, I'd consider using the other genuine switches with the more pronounced toggle for a little more leverage. Just a thought.
Old June 23rd, 2016, 03:42 PM
lithium1330
'97 SW NAS 4.6
Thanks for responses. Very helpful!
I was able to wire up additional factory switches for aux fuel pump (under side), and then 3 switches in row (front driving lights, rear work light and dash brightness).
There were 6 screws needing removal:
- 1 left, long screw holding down the heater control to left side of the instru cluster,
- 1 screw holding the plastic cover to the door swing arm - just need to remove the plastic cover.
- 2 small screws at bottom of that panel (near your knees)
- 2 bigger screws holding the AC vent to the panel (one you'll find looking under the AC panel, other is inside the vent).
The whole panel then just wiggles out.
Overall, pretty easy job! Thanks for the input here.
And hope this helps others.
switch, wheel
Defender D90 D110 Steering Switches Controls Signals, Lights, Wipers, ROW arcteryx33 For Sale - Parts 0 January 6th, 2016 09:02 AM
Attempting to add power steering to 2.5na jafir Defender Technical Discussions 42 October 22nd, 2015 10:13 PM
DI switches bezel with switches RoverPaisa For Sale - Parts 2 February 12th, 2015 07:49 PM
Toggle switches Roverlab Series Technical Discussions 0 January 22nd, 2015 03:15 PM
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
