AC recharge - Defender Source
Old June 3rd, 2013, 08:29 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
AC recharge
It's that time of the year again here on the east coast. The humidity is starting to kick ass on some days. I don't run the AC much but my 97SW tends to need a recharge every couple years now.
Yesterday I stopped by the auto store and bought a recharge kit for $30, read the 3 step directions and did it right there in the parking lot.
Worked great. I'm fully charged and the kit is reusable so will only need a can of gas next time.
A couple years ago I got talked into recharging it while I was at a local shop getting tires mounted. That was about $90 and seemed to take them forever to run the die and tell me what I knew already.
Nice simple fix so I thought I'd pass it along.
Clay
Old June 3rd, 2013, 08:41 AM
Clay
I guess your system was low ... the reason it took longer before was they used a vacuum to pull all the air and moisture out of the system so that it would run a t peak efficiency. Using these cans with a system that is totally empty of had a leak is a complete waste of time and money ( ask me how I know ).
Old June 3rd, 2013, 09:10 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Yep. We still need to find that leak.
------ Follow up post added June 3rd, 2013 09:12 AM ------
Clay
The only issue is that air is still trapped in your system. If it leaks out again get a cheap set of hoses and vacuum pump (maybe 40 bucks) from harbor freight and try to locate the leak. I found my leak and had a hydraulic hose guy make me up a new one.
Old June 3rd, 2013, 09:20 AM
tjfslaughter
thomas
Burbon
This is the pump I have, works well:
http://www.harborfreight.com/air-vac...ors-96677.html
Hose set:
http://www.harborfreight.com/a-c-man...set-92649.html
If you get a hose set make sure it has negative pressure on the gauge.
Here is a good how to guide:
http://www.firstfives.org/faq/AC/ac_charge.html
AC clutch not engaging (94 D-90) down_shift Defender Technical Discussions 16 August 25th, 2012 04:27 AM
ac recharge issue Rufus Defender Technical Discussions 1 September 18th, 2011 09:19 AM
AC recharge td5 Ben01 Defender Technical Discussions 2 July 14th, 2011 11:48 AM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
AC Recharge - Valve size d90xjay Defender Technical Discussions 0 June 8th, 2006 11:51 AM
