97 NAS: Garage Queen to Daily Driver/Overland Use. - Page 8 - Defender Source
Old August 9th, 2014, 08:26 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Thanks fellas.
So here I lay under the 90 replacing the gas tank skid with Safari HP's skid. I was pleasantly surprised to see I have a plastic tank...I thought they were all metal.
Plastic or not, its a good idea to remove and clean periodically as there is enough crud and gravel accumulation to puncture the tank over time:
Pic above shows 550 cord on each side of the frame and under the tank to hold it up while I replaced the skid.
Old August 9th, 2014, 08:47 PM
the rover shop
shayne young
Every nas90 truck I have seen has the plastic tank, and yes, it's definitely a good idea to pull that down periodically or at least get in there and give it a good hosing out.. The build up of mud which then holds moisture rots out the cradle and the chassis.. And last I checked you can't buy the rear nas subframes anymore.. Lube the bolts with anti seize when reassembling and spray periodically with boeshield..
Old August 9th, 2014, 09:19 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Good to know, thanks! My frame looks solid thankfully.
Old August 16th, 2014, 04:04 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
A shoutout to nathanwind, Jason Lav, for the solid wing top mounts. Finally screwed them on with stainless screws after a year or so in the garage; perfect fit and finish. Must have IMO.
Refinishing my rear end as well... Replacing all hardware to Grade 8 or higher in zinc/stainless, sanding, painting with Eastwood, installed Safari HPs aluminum skid, new fuel filler hose, tightening up the wiring to the Wipac LEDs, etc. Pictures and reviews to come.
97, nas
1/USED NAS D90 (95 and 97) round reverse lamp housing-lens - $10.00 NashvilleRover For Sale - Parts 5 October 17th, 2009 09:06 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Daily Driver/Off-Road Only/Garage Queen? Grover Misc. Chit-Chat 41 November 12th, 2007 12:09 AM
Garage Cleaning - Everything Must Go!! m.michaels For Sale - Parts 13 February 7th, 2006 03:02 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
