97 NAS: Garage Queen to Daily Driver/Overland Use. - Page 2 - Defender Source
Old January 21st, 2013, 10:59 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by SMac View Post
Instead of the $40-50 at the local box shop, I picked up an AC-151 Stepper Motor for $13.95 off fleaBay with a so called "lifetime" warranty:
http://www.ebay.com/itm/NEW-GLOBAL-A...5c3f7b&vxp=mtr
The options from NAPA (Echlin 2-1856), Autozone (AC-151), and this "Global Automotive (AC-151)" all look remarkably similar.....
$13.95 shipped no less. Thanks for the tip. Just ordered one as a spare (but will make sure it works first).
Old January 21st, 2013, 02:51 PM
If you could make sure to report back whether it works or not once you've tested.
Old January 22nd, 2013, 04:56 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Got the Magnaflows in. Great looking tip, both pieces look well made.
Hope the oxygen sensors fit the factory plug....
Old January 23rd, 2013, 05:29 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Finalized the suspension with Justin today. End state was minimal lift (1-2"), increase in flex, and better/longer bump/washboard control. I may kick myself for not going up to the resi Fox.
Fox 2.0 Emulsion Non-Resi 10" Travel Shocks valved at 85/90 all around
OME 751 Fronts
OME 764 Rears
Terrafirma Front/Rear Dislocation Cones
Terrafirma Front/Rear Spring Retainers
RTE shock mounts all around
I'll probably add genuine spring isolators for noise/vibration attenuation and might also need extended bump stops.
Funny how the parts list has morphed from what I originally planned. For the better I hope, definitely more dough though... I keep getting talked into things.
Old January 28th, 2013, 08:36 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Parts, parts, and more parts.
Old January 31st, 2013, 07:48 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Should have done the oil cooler lines sooner, but thankfully I've made it this far. These Trailhead 4x4 lines look slick, and Justin even managed to kick in a discount. The SafariHP rear speaker housings are very well constructed as well; thinking of Dynamatting the inside of the housings prior to install.
And to switch it up a bit.......
My guys hanging a few 120mm mortar rounds:
2012 Idaho Whitetail....
Old January 31st, 2013, 09:31 PM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
Let's see a pic of all the stuff I passed on from Helobubba...just to add salt to the wounds.
Old February 3rd, 2013, 04:01 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I think I have everything I need for a comprehensive rebuild third member out...minus hubs. Rave, don't fail me now!
ID:	65661   Click image for larger version
ID:	65663   Click image for larger version
Old February 11th, 2013, 06:06 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Well, no Defender but more parts!
Ive already got buyers remorse. Should of went Resi.....
10" travel with OME 751/764
Old February 11th, 2013, 08:19 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I'm sure you'll still be pleased with those. Any word from Luke?
My other car's a Land Rover
Old February 11th, 2013, 09:05 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
None yet Kevin. I'm so interested in that 3.2 PS coming out in the Transit van this fall that I'm probably just going to have Luke fix whatever is chattering, seal the engine up front to rear, and wait for a couple years for a transplant. Thanks again for the lift!
Old February 13th, 2013, 08:30 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Sears Diehard Platinum batteries are on sale for $189 right now versus the regular $220, at least here in Middle Earth.
Also found that TireBuyer.com seems to have the best prices on tires, shipped.
Old February 13th, 2013, 09:52 AM
DGH
David Howe
I bought one yesterday in Warwick, RI. Retail was $222, no sale. They gave me a 10% discount when I complained that they were listed at $188 online.
2011 LR4 Metropolis (white)
2003 DII Santorini Black (I think)
1981 FJ 40 Beige
Defender - in the market
Old February 13th, 2013, 01:42 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Crap, I should check to see the local price as well. This was the online price after I input my zip. I assume they want a core...
Old February 24th, 2013, 07:45 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So off topic again as the 90 is still in the shop. I put front brakes on the LR3 a while back but cosmetically they look like garbage already with surface rust. I went with the OE rotors from AB and genuine pads, the rotors come in an AllMakes box and obviously have no rust inhibitor on them like the genuine ones do. So I taped and painted the rears prior to install with caliper paint in an unobtrusive silver. Stripped and washed the hub area and took some steel wool to it prior to paint. Nothing fancy, but it should last till someone finds me a Black/Black Lux Limited LR4....
Old February 24th, 2013, 07:58 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
A couple small things I did a while back. Some hot start issues solved I believe with some PCV line replacement:
One line was split wide, and the other had a crimp in it and a completely clogged oil separator.
And the all too common taillight issue:
Besides a bushel of Georgia's finest red, the harness was rusted out. Replaced temporarily with a Wipac LED; waterproof crimp is the way to go here I think.
Old February 27th, 2013, 09:50 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Any luck finding a black/black lux?
Old February 28th, 2013, 08:47 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Yep, found a few that we specd..., minus HD, in Texas and Cali. We are going to wait till this fall when we get to Texas. Seems as though the Southerners like their LRs too much as the "shortage" seems to be limited to the Southeast. Minus the new RR of course. I about pulled on a Cpo in Cary NC but wife finally put the kabosh on that.
Old February 28th, 2013, 02:30 PM
How's the exhaust? Photos..
Old February 28th, 2013, 02:56 PM
WD90's Avatar
WD90
Dan
Was going to mention the one we just put on the showroom...
97, nas
1/USED NAS D90 (95 and 97) round reverse lamp housing-lens - $10.00 NashvilleRover For Sale - Parts 5 October 17th, 2009 09:06 PM
WTB 97 NAS D90 AC system ECR Wanted 7 July 16th, 2008 07:58 AM
Daily Driver/Off-Road Only/Garage Queen? Grover Misc. Chit-Chat 41 November 12th, 2007 12:09 AM
Garage Cleaning - Everything Must Go!! m.michaels For Sale - Parts 13 February 7th, 2006 03:02 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
