94 NAS Chassis Harness - Defender Source
Old February 2nd, 2013, 09:11 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
A couple of notes for those looking to replace a faulty chassis harness in a 1994 NAS truck:
First off, as far as I know, there aren't any new-old-stock harnesses available anymore. The solution I found is to get in touch with Josh at British Wiring. You'll need to pull your old harness, carefully preserving all of the connectors, and send it to him. If you have to clip a wire, be sure to include the clipped ends. He'll send it off to the UK and two or three months later, you'll get a beautiful new harness back, custom-made to match the original.
Now, there is one thing that you'll want to request from BW. Ask them to install the terminal ends on the forward-most end of the harness (where it plugs into the main harness in the engine bay) but ask them to not insert the terminals into the plug housing. This will make it much easier to pass through the narrow gap between the body and the frame outrigger. If they forget and send you a harness with the plugs already installed, it is possible to remove them by hand. First, carefully pop out the yellow plastic inside of the plugs, then use a tiny screwdriver to move each plastic barb from each terminal out of the way, which allows you to pull the wire terminals out of the plug, one at a time. Pain in the ass but it can be done.
Once you get your new harness, you'll notice that there is no fuel pump plug connector. Apparently these are NLA. No worries: order a four-terminal Weatherpack connector off of eBay and install it on your fuel pump harness. As a side benefit, it will do a better job of keeping water and mud out of the terminals, important since they hang right behind the rear tire.
I have a couple of tips for installing the harness:
Use a wire fish, like the kind electricians use, to pull the harness through the frame.
Tape the loose terminal ends to the harness with electrical tape to keep them from getting snagged. Try to arrange them so that the thickness of the bundle is minimized, to make it easier to pass through the frame.
The rear part of the harness is shaped like a 'Y', with the two branches going to each taillight. Left alone, these branches can be hard to pass through the frame. You'll want to tape one of them to the other. Whatever you do, don't tape one of the branches to the forward-most part of the Y. If you do this, you'll pull the harness through the frame and find that you can't retrieve the taped-down section because it's still halfway up the frame. Tape the two rear branches of the 'Y' to each other instead.
Take your time and be gentle with the harness. A snag could tear the wire coating and expose copper, quickly corroding your nice new harness.
Old February 2nd, 2013, 09:19 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Do you have photos of this beautiful new harness?
Old February 2nd, 2013, 09:25 AM
Pics? Price? I thankfully ended up not needing a new harness to fix my light faults.
Their site is down currently (hopefully they didn't go out of business) but you used to be able to get the stock connectors through Autosparks.
The connections to make them plug and play are pretty easy. They're just these.
C-862 (2-pin) Female, quantity (3)
C-863 (3-pin) Female, quantity (2)
C 862
http://www.autosparks.co.uk/product_...oducts_id=1770
C 863
http://www.autosparks.co.uk/product_...oducts_id=1771
Site:
http://www.autosparks.co.uk/index.php?cPath=94&page=4
Old February 2nd, 2013, 09:35 AM
chris snell
Chris Snell
87 Ex-MOD 110
Sorry, no pics. The British Wiring harness is a thing of beauty, like travelling back in time to 1993 and pulling a fresh one from the box at the factory.
The NLA plug I refer to is the fuel pump harness at the rear of the truck. A new harness will come with the front plugs.
I don't remember the price, maybe somewhere around $200. I remember thinking that it was very fair and much less than I'd expected to pay.
Old February 3rd, 2013, 01:16 AM
Does BW now have a pattern since the built one for you?
nas
complete 94 NAS d90 3.9 electrical harness/ecu lrna04 For Sale - Parts 7 June 29th, 2012 03:17 PM
94 NAS on Craigslist 23500 NoVaKevin The Flea Market 13 May 23rd, 2012 12:31 AM
Original NAS Cubby Box - '94 founD90 For Sale - Parts 7 April 19th, 2012 04:39 PM
NOS genuine doors for 94 NAS leafsprung For Sale - Parts 6 April 5th, 2011 06:27 PM
Heater-AC Vacuum Harness Diagram 1993 110 NAS R. Kurk Defender Technical Discussions 17 July 14th, 2009 05:04 PM
