'84 300 Tdi 110 Fuel Tank - Defender Source
Old August 31st, 2011, 10:33 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Just a quick question regarding fuel tanks. My 1984 Defender 110 has a fuel tank leak. The tank is steal - part number NRC7570. I need to run some of the fuel out of the tank this week before dropping it to inspect. I suspect the leak is occurring at the front tank seam where the cradle mount is. In addition, there is a surprising amount of dirt and grime leaking from the cradle/tank edges - I am concerned what the tank will look like between. Phone conversations have suggested approx. $200.00 for the repair.
I also have noticed later plastic tanks for sale. Outside of the obvious benefit regarding corrosion here in Canada - are there any other benefits to the plastic tank. Would this conversion be possible on my chassis - knowing Rover I assume the chassis design wasn't modified to accommodate the plastic tank? Outside of the sender - would there be any additional costly parts required to convert?
Much obliged...
Henry
Old September 1st, 2011, 07:37 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The original tank was one piece as in the cradle was part of the tank and they all pretty much rusted out (like the RRC tanks that all failed....actually the same tank) There is nothing really wrong with the new replacement tank with the separate cradle. Fitting the plastic tank is a pain in the arse and considerably more expensive .
Matt Browne
Old September 1st, 2011, 11:00 AM
And yes there are chassis differences - the plastic fuel tank cradle is hard to get (although I think someone had some made up recently) and expensive. I'd just get a new tank, or seal/repair the one you have if it isn't bad.
Originally Posted by pendy
I'm here for the D's
Old September 1st, 2011, 09:02 PM
Shearpin
Henry Stinson
Thanks for the posts - I'll pull the one I have and take a look at how bad it is...
Regards,
Henry
110, 300 tdi, fuel, fuel tank, tdi
Need Fuel Tank Image NRC9225 isleofbones Defender Technical Discussions 9 April 16th, 2011 09:52 PM
Mantec Fuel Tank Install on a NAS 110? R. Kurk Defender Technical Discussions 8 October 9th, 2009 12:25 AM
1993 Defender 110 300 tdi $23,500 captainz For Sale - Vehicles 5 February 22nd, 2006 01:58 AM
stainless fuel tank skidplate rvrsrvc Wanted 2 November 3rd, 2004 12:29 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
