8274 Rebuild / Install - Page 2 - Defender Source
Old November 19th, 2014, 08:28 AM
20' of Royal Excelene 3/0 cable. Designed to run from the battery ground / pos to the winch solenoid pack. I've looked at using commercial heavy-wall tinned copper lugs, but it looks like crimped, soldered, and flattened copper tubing is actually the best for serious current.
I had bought some audio cable off ebay that ended up being CCA, which I deemed not appropriate.
Old November 19th, 2014, 01:49 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
where'd you order that from?
Old November 19th, 2014, 02:07 PM
weldingsupply.com
Old November 19th, 2014, 02:11 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
weldingsupply.com
Great place to get that stuff, I've spent some coin there...
Old November 19th, 2014, 02:12 PM
Old November 19th, 2014, 02:40 PM
jrose609's Avatar
jrose609
Jason Rose
weldingsupply.com
great. Thank you.
Old November 19th, 2014, 02:42 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Nice write up ! I love these old winches and building them up is one of my hobby's . I have been putting the warn 9.5 XP motors on these when we go thru them . Really nice upgrade and can be had on Amazon for pretty cheap .
85 D110 3.5 3 DR
Old November 23rd, 2014, 05:06 PM
Thanks again guys
Ed - question for you - do you run your 8274 with the solenoid pack under the bonnet or mounted on the winch motor?
If you put it under the bonnet, where do you put it? As the picture shows, I have precious little room available. At first glance, the only place the solenoid pack will fit is next to the washer bottle.
Old November 23rd, 2014, 06:52 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Thanks again guys
Get rid of the Warn box. Get a single Albright contactor(if you don't already have one) and you can mount it almost anywhere. Its pretty small.
You can remote mount the plug to your grill, bumper, whatever. Or run in-cab controls. Or have both, like me.
Old November 23rd, 2014, 07:06 PM
Good point Brett. I can definitely just run the old solenoid box up front until they give up the ghost and then switch to the albright at a later date.
Old November 23rd, 2014, 07:09 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Second the Albright pack, it fits in the factory spot with slight modifications and is such a better solenoid than the factory four.
http://m.summitracing.com/parts/spw-90-14452
Defender 110
Old November 23rd, 2014, 10:38 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks again guys Ed - question for you - do you run your 8274 with the solenoid pack under the bonnet or mounted on the winch motor? If you put it under the bonnet, where do you put it? As the picture shows, I have precious little room available. At first glance, the only place the solenoid pack will fit is next to the washer bottle.
I use the Albrights I ship in about 30 a year up here . It's the only solution to a dependable winch .
I put them on the ends of the motor or under bonnet . Depends on the situation .
85 D110 3.5 3 DR
Old November 23rd, 2014, 11:41 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
I'd recommend getting the Albright before you NEED it.
Its a D1, but here's how i mounted my Albright.
Remote plug above the Hella in the grill.
Landy_Andy's Avatar
Landy_Andy
Andy
If people want to mount the Albright on the end of the motor GP make custom motor mounting bolts to do that... Might as well fit some upgraded internals too 😃
Old November 24th, 2014, 01:32 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
When I rebuilt my M12000, I used a Warn Contactor kit. Although it's a little overpriced, it made for a nice and sharp installation and has been super reliable.
http://www.amazon.com/gp/aw/d/B004YT...=AC_SX200_QL40
Old November 24th, 2014, 11:43 PM
aka rover's Avatar
aka rover
ed angel
95 D90
[URL=http://smg.photobucket.com/user/fishEH/media/IMAG0416_zpsd49ab9a3.jpg.html][IMG]
that albright looks dangerously close to the metal .
this is what Andy was talking about
85 D110 3.5 3 DR
Old November 24th, 2014, 11:50 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
It's not, just the angle. Probably at least an inch clearance.
Old November 25th, 2014, 12:13 AM
aka rover's Avatar
aka rover
ed angel
95 D90
yes hard to tell in pics alot of times
85 D110 3.5 3 DR
Old November 26th, 2014, 08:36 PM
I now have a Superwinch 90-14452 on order. This is the Albright DC88P copy with center-to-center mount spacing of 3.40". The 8274 motor mount bolts have a 3.43-3.50" spacing so all that should be required to mount the contactor directly onto the winch motor are two 0.75" spacers, longer motor mount bolt/studs.
The motor length is approximately 5.9-6" with apparently 1/4"-20 threads. So I need studs that are at least 7 inches long. Probably using stainless now.
I also looked at the Warn 34971 but I don't see the point.
Old December 1st, 2014, 10:26 PM
Waiting for my 4/0 terminal lugs to come in.
The switch is a carling two-position momentary (up - winch out, down - winch in)
Going for a Gigglepin-style end-of-motor mount. Stainless adjusting studs are extra length to fit an upgraded 9.5xp motor if my prestolite ever dies.
rebuild
8274 rebuild Abrooks Misc. Chit-Chat 54 March 29th, 2012 11:04 PM
Relocating Warn 8274 solenoid pack? KevinNY Defender Technical Discussions 19 April 2nd, 2008 08:42 PM
Warn 8274-50 Used chrisvonc For Sale - Parts 18 November 13th, 2006 05:52 PM
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
