300Tdi rebuild - Page 5 - Defender Source
Old November 22nd, 2014, 10:29 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by ini88 View Post
Little spin around the yard. Timing set correct this time. Straight through exhaust. No fuel mods on the IP yet. Its a strong rebuilt 300.
Good work my man.
Old November 22nd, 2014, 10:33 PM
Drive that thing to Williamsburg, I want to check it out!
Old November 23rd, 2014, 06:55 AM
Originally Posted by rijosho View Post
Why does it sound like farts?
It's just nervous
Old November 27th, 2014, 11:13 AM
Missing somthing?
-Jeff
He's saving weight to make up for the power loss from the 300 Tdi install.
Old November 27th, 2014, 12:00 PM
The incredible low down torque of the 300 tdi ripped them from their holes.
Old November 27th, 2014, 12:11 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Missing somthing? -Jeff
I had that wheel off to fit the exhaust pipe. Just hand tightened it back on. Trust me the whole truck is like that right now with little bolts here and there and missing after surgery
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old November 27th, 2014, 01:31 PM
You allowed Jarek to drive your truck?
Haha jason wasn't there. It was either Will (airbornrover) or Jarek. Jarek was driving it and I was filming
Old November 28th, 2014, 12:36 AM
ini88's Avatar
ini88
Daniel Marcello
Only when he is drunk off vodka.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 6th, 2014, 03:40 PM
ini88's Avatar
ini88
Daniel Marcello
I have a weird thing going on. Driving in 5th hauling ass and I'll pop it into neutral and the engine will cut out. It does this even when I rev the hell out of it... It will stumble, maybe stall or just catch itself.
Doesn't do this at lower revving.
Could this be fuel delivery at idle? The top torx screw on the IP cover?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 6th, 2014, 05:20 PM
I have a weird thing going on. Driving in 5th hauling ass and I'll pop it into neutral and the engine will cut out. It does this even when I rev the hell out of it... It will stumble, maybe stall or just catch itself. Doesn't do this at lower revving. Could this be fuel delivery at idle? The top torx screw on the IP cover?
Time to join a UK forum ...
Old December 6th, 2014, 06:09 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Time to swap a ZF.
Old December 7th, 2014, 12:57 PM
only thing I've had cause my engine to cut out is the connector to the IP shutoff solenoid. Check it isn't loose. I squeezed mien down to make it nice and tight. Now it's all better.
Old December 29th, 2014, 08:08 PM
ini88's Avatar
ini88
Daniel Marcello
Who here is running a 300tdi with a 1.2tc, 3.54 diffs and 33" tires? Do you like the ride and can you pull 70-75 easy on the highway?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 29th, 2014, 08:13 PM
I have a 200tdi like that. There is no problem with pulling 5th gear. The higher gearing is much better for the highway. 75 is easy.
1st can be the problem. It is okay for a 90 but a bit much for a 110.
Old December 29th, 2014, 08:14 PM
I fit that bill now after my conversion....EXCEPT I've got a 1.4tcase. Absolutely no problems at all hitting 70-75, so I'd assume a 1.2tcase would give you an even higher top-end.
Old December 29th, 2014, 09:29 PM
ini88's Avatar
ini88
Daniel Marcello
Yeah I have a 1.2 with 4.11s and I'm topping out a bit with 35" tires. Over revving at 70mph but I also upped the fuel.
May go with 1.2/3.54/33" and see how it goes. The overdrive only fits a 1.4tc sooooo that will be up for sale soon!
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 29th, 2014, 09:42 PM
Reserve licked
Old December 29th, 2014, 10:08 PM
Tell me more about this overdrive?
Old December 30th, 2014, 12:35 AM
ini88's Avatar
ini88
Daniel Marcello
Its a GKN overdrive which is different than the Roverdrive you usually see. I think it's a .72 ratio. It's solenoid driven which has its ups and downs. It fires instantly so no lag between on and off (no clutching or letting off the gas). Only down side I can see is wires but if you wire it correctly and cut out the speed sensor then it's bulletproof. You wire it off a relay and switch... Stupid easy. They had a speed sensor so you cant switch it on before 30mph which is technically true with most overdrives but I'd just skip that because the control box which links it all together is prone to causing problems. Just keep the wiring simple.
Anyways it gives you a split 4/5 gear or a 6th gear. I found out today that the input gear is 26th toothed which is set to a 1.4tc. I put a 1.2q box from a disco2 in and forgot about the 38 tooth gear.
If I can get it to work on a 1.2 ohhhh man.
Devon4x4 now bought out all of GKN's spare parts as they don't make them anymore. RN has one for sale I think
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 30th, 2014, 11:38 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Dan it could just be the pump governor that is sticky from being in storage for a long time. VE's will do this. Best thing would be to run some ATF through it and just drive it. It may solve itself. Just add some ATF to every tank, a quart or two should do it.
Like Dave said, it could also be the shutoff solenoid but this sounds like a governor issue. I had all kinds of weird symptoms with a VE pump on my 6BT that were traced back to a gunked up governor. The more miles I put on it, the better it ran.
JL
tdi, rebuild, 300tdi
300tdi rebuild manual PDF ini88 Defender Technical Discussions 7 September 22nd, 2011 03:12 PM
ECR fresh NAS 110 rebuild with 300tdi, $160,000 evilfij The Flea Market 100 March 17th, 2011 01:11 AM
International 2.8 or 300TDI for rebuild Marinerover Defender Technical Discussions 31 March 5th, 2011 07:16 AM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
tranny rebuild mattdh Defender Technical Discussions 15 November 12th, 2003 01:09 PM
