300Tdi rebuild - Page 3 - Defender Source
Old July 29th, 2014, 03:38 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Why not just take it off on a transmission someone should have laying around? Does a Series clutch alignment tool work?
Old July 29th, 2014, 03:48 PM
They are different, but you don't need one. You can do it by eye. A socket extension with some tape on it is fine. The pilot bearing is really big, so it is easy to do and check by looking at it.
Old July 29th, 2014, 03:49 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I might have one at Greg's house. I can't remember where I put that one R380. Randy should have one and no the Series doesn't work. I could use a socket but id rather get is straight then slightly off.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 29th, 2014, 04:07 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Let me see when I get home. I cut the input shaft off an LT77 and I believe that will work. Will definitely need it back.
Old July 29th, 2014, 05:00 PM
Dan,
I have a spare r380 input shaft you can use.
I can bring it to NJ on Friday.
Originally Posted by ini88 View Post
Would anyone on the board have a clutch alignment too I could borrow? I would pay for shipping it out and back to you.
Old July 29th, 2014, 05:13 PM
ini88's Avatar
ini88
Daniel Marcello
Originally Posted by Ren Ching View Post
Dan,
Thanks Dave. I have 20 spare Everything bagels from The Bagel Store you can use.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 29th, 2014, 05:15 PM
Deal.
I will return the bagels when you return the input shaft.
Old July 29th, 2014, 05:22 PM
ini88's Avatar
ini88
Daniel Marcello
Deal.
I just need it for like an hour. Engine is at Jareks.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 15th, 2014, 04:20 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Sounds good Jimmy! I already have the 1.4TC in there. I need to figure out gearing after the engine is in and running. I have stock diffs in and spare 4.11s I could throw in. But the truck is also downsizing to 255/85 tires after the swap. Anyone else have their truck running good highway speeds with a 1.4tc/3.54diff or 1.2tc/4.11diff with 255/85 or 33" tall tires? I have an over drive I will be fitting to the truck too
My dad's truck is 300tdi,1.4,3.54,285/75. Runs nice but for highway cruisin he also has an overdrive
Legend in My Own Mind.
Old August 15th, 2014, 04:28 PM
I have the referenced drivetrain spec and 255's. Drives great. OD would be nice but not necessary. Off road it's a beast. Lower gear would be fun but so far not needed.
Old August 15th, 2014, 04:45 PM
ini88's Avatar
ini88
Daniel Marcello
Randy I still need to come pick up those engine mount templates. I didn't see them in the box you gave me.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 15th, 2014, 05:03 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I'm a tool. Totally forgot. Let me know and I will have them ready for u
Old August 16th, 2014, 01:36 AM
Dan I think I forgot the input shaft. Do you still need it?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 16th, 2014, 10:20 AM
ini88's Avatar
ini88
Daniel Marcello
Its all good Randy, I'm setting the clutch today so I can bring that tool back to you.
Dave, no worries on the input shaft. Randy let me borrow his clutch alignment tool.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 18th, 2014, 11:24 AM
ini88's Avatar
ini88
Daniel Marcello
Does anyone know if the V8 slave clutch is the same as a 300tdi?
I see part numbers:
FTC3911
FTC5072 (which reads out for 200/300tdi, V8)
FTC5202 (which says 300tdi & TD5)
Also I believe the push rod is different too.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 18th, 2014, 11:42 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I see part numbers:
FTC3911
I read it as FTC5071 for V8
FTC5202 TD5
FTC3911 & FTC5072 200/300 R380 Tdi
591231 on the Lt77
these are for Defender units
But I could be wrong my look-up book is getting dirty and dog eared
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 18th, 2014, 04:16 PM
tdidisco
Jim
1995 Tdi Disco
The slave cyl. is the same I used my v-8 one when i did the conversion
Old September 18th, 2014, 05:09 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks Jim! did you use the same push rod to clutch fork?
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 19th, 2014, 12:11 AM
tdidisco
Jim
1995 Tdi Disco
I don't remember but I think I did.
i would try it and see if the slave fits with the push rod.
Old September 22nd, 2014, 01:18 PM
ini88's Avatar
ini88
Daniel Marcello
So the V8 and 300tdi clutch push rods happen to be different lengths. This might be due to the different clutches or forks you use. Anyways I went with the 300tdi ones.
Also dropped the engine in this weekend. welding in the mounts with the very simple jig was a bit scary but damn it all lined up perfect! So perfect that that R380 mount dropped right into the cross member.
So I have to run a SS or soft clutch line from the driver side to the passenger side. Im going to skip the long hard line for the original LHD 300tdi. Does anyone know the fitting size for that? i've been reading it might be 7/16 UNF
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
tdi, rebuild, 300tdi
300tdi rebuild manual PDF ini88 Defender Technical Discussions 7 September 22nd, 2011 03:12 PM
ECR fresh NAS 110 rebuild with 300tdi, $160,000 evilfij The Flea Market 100 March 17th, 2011 01:11 AM
International 2.8 or 300TDI for rebuild Marinerover Defender Technical Discussions 31 March 5th, 2011 07:16 AM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
tranny rebuild mattdh Defender Technical Discussions 15 November 12th, 2003 01:09 PM
