300tdi Oil Warning Light Sender - Defender Source
Old June 29th, 2016, 08:45 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
I have determined my 300 tdi engine oil leak is coming from the oil pressure warning light sender; it appears to be dripping from the electrical contact area.
I ordered PRC6387 but have found the treads are wrong - too big. The threads on my leaking sender appear to be M10, and the part is tapered at the end. Anyone else run into this problem? Every retailer website I've visited lists PRC6387 as the proper part.
Any alternative part number suggestions?
Thanks again,
Henry
Old June 29th, 2016, 09:38 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
You're right it's m10 thread. Did it come with a new crush washer?
Old June 29th, 2016, 09:46 PM
Shearpin
Henry Stinson
PRC6387 did come with a crush washer - unfortunately, the threads are not M10. There must be a different part for this application...
Thanks for the reply.
Henry
Old June 29th, 2016, 09:56 PM
Broncoduecer
peter
D90
That's the one I bought for mine for my 300tdi. I see another number but the the part doesn't look like it has the right connector.
Old June 29th, 2016, 10:53 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Mine has 1/8 NPT (tapered pipe thead). No crush washer needed, just thread sealant.
Eric.
Old June 30th, 2016, 12:10 AM
Shearpin
Henry Stinson
Thank you for the replies...
Can anyone confirm the thread type for PRC6387? I just measured the threads on the PRC6387 I was shipped, and it is definitely not M10. It is possible the sender was put in the wrong box.
I did find a thread on a UK forum asking this same question and it fizzled out with no consensus - M10 or 1/8 NPT.
Is anyone aware of another part# for the 300 tdi oil pressure warning lamp sender with m10 threads?
Much appreciated...
Henry
Old June 30th, 2016, 12:19 AM
Hit up Brian at Defenders Northwest. If anybody knows the answer and the part number it will be him.
Old June 30th, 2016, 07:20 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mine is M8 1.0.
I may have a new sending unit and crush washer in this size if it helps you out.
RDavisinVA
Old June 30th, 2016, 07:42 AM
Broncoduecer
peter
D90
This has something about when 200 and 300 switched
300TDi oil pressure sender for factory gauge - Defender Forum - LR4x4 - The Land Rover Forum
Old June 30th, 2016, 05:36 PM
Shearpin
Henry Stinson
Hey, thanks for the link. Reading the thread over, it looks as though the poster is converting to a pressure guage. It does confirm I need m10 x 1.0 threads.
It could be the box I got marked PRC6387 contained the incorrect part - it has got me confused. I have confirmed the part contained within is 1/8 NPT thread.
Henry
300tdi, ht, tdi
