200tdi Swap into a 88 UK d-90 - Defender Source
Old May 13th, 2012, 10:30 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Started my 200tdi swap today. I'm doing a time lapse video of the whole install. Heres a few snapshots from the pics today. Basically started from the front and got the radiatior and fan shroud out, and the air filter assembly. Only put in a an hour or so on it this far.
While its out I'll take some time to clean the very greasey engine bay.
Much more to follow... lets just hope this engine works.... if it does I'll have a 2.5TD for sale!
ID:	51524   Click image for larger version
Old May 15th, 2012, 10:42 PM
bossman429's Avatar
bossman429
Adrian
1988 90
So I got the engine out today
All in all pretty damn easy. I can't beleive I didn't run into one bolt that I broke, or was rusted on. I guess the layers of grease kept everything rust free. That being said I got alot of grime to clean out of this engine bay and off the frame!
Things to note - there is one bellhousing nut just below the starter on the upper/middle left hand side, make sure you find it and remove it before you try to take the engine out lol
Tie the hood up before removing the prop
you can get all the bellhousing bolts from either below or in the engine bay. Raise the engine a bit, remove the rubber isolated on the mounts, then drop it back down. This will give you some extra clearance to get at all the bellhousing nuts. They ar 17MM and pretty easy to get at.
I posted this in the tech section but I'll ask here too..... does anyone know if I need a different radiatior frame/housing to house both the radiatior AND intercooler? Also is the fan shroud different?
The rest looks like it will bolt right back up
Old May 16th, 2012, 09:24 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
The radiator surround and fan shroud are different, that should've been supplied with your 200tdi.
You'll need to remove your air filter as well, the intercooler hoses will be occupying that space.
Old May 16th, 2012, 04:46 PM
Naplm00
Matthew
if you want you can take a look at my truck, had the same swap done
Old May 19th, 2012, 07:00 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
dude, I forgot the weekend is already on us (WTF I just got a good pace going) and I cant get the parts out 'till Monday. Hope that doesn't fawk it up!
Matt Browne
Old May 19th, 2012, 07:45 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Monday is fine. Sent you some coin. Should have this thing running in a week or so.
Old May 20th, 2012, 06:27 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Thanks mate. I was about to take a frame of an old rad when I found a NOS set in the pile all shiney and complete with new rubber grommets and nice new bolts. You win
Matt Browne
Old May 20th, 2012, 09:46 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
We got in 90% done! only some small bit remain but it was a very quick and easy install from what I can see.
Matt, Adrian said you might hook him up with a 200tdi radiator frame? Do you have any 300tdi Radiator/intercooler frames? I need one for my convert.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 20th, 2012, 11:43 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Awesome man your the best!
------ Follow up post added May 20th, 2012 11:45 AM ------
All in all pretty straight forward. all thats left is the radiatio/intercooler and some plumbing. I have to get that fuel line made up which will probably take a couple days for the parts to come in.
Pretty darn close to getting this thing fired up!
Once complete I'll go through what I did in detail with any qwirks that popped up along the way
Old May 20th, 2012, 10:18 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
With a turbo that accessible in the engine bay, i would be so tempted to put a bigger one in. :D
Swap is looking good so far, looking forward to the end results.
Did you do anything to the motor before install? I don't know what type of diesel they had where this motor previously ran but i know in my vw tdi that had many miles on it on the pre ultra low sulfur diesel that the intake manifold had a good amount of carbon buildup, and it pulled way harder through gears after i cleaned it. And some bigger injectors and some tuning to the the motor and it could be a quick little car. But I'm sure you know all this stuff.
Old May 20th, 2012, 11:37 PM
bossman429's Avatar
bossman429
Adrian
1988 90
This was supposedly a fresh rebuild that hadn't been run and sitting since 2009. Not sure if that's 100% accurate but nope didn't really do much. Could care less about max performance. I want reliability, a decent cruising speed, mileage offload and o yea reliabiltiy. I'm gonna bleed the whole fuel system so the little bit of diesel that's in there is of little concern since its so little.
Old May 21st, 2012, 12:07 AM
JohnsD90's Avatar
JohnsD90
I hear that. Just remember, more power means less effort to get up to speed, which in turn gives better economy and less wear and tear. I'll leave ya alone now lol.
Old May 21st, 2012, 12:23 AM
bossman429's Avatar
bossman429
Adrian
1988 90
To a degree A factory 200tdi with my setup should get to and hold 65-70 without much effort. Controlling your right foot has a lot to do with it too lol
No sweat I enjoy the input.
Old May 21st, 2012, 11:45 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nice!
There is a SIII 109 SW in town that I see parked in the corner of a local gymnastics place. Everytime I see it I think a galvy frame and a little fix up would be nice. And 2.5 diesel that you just popped out could be a good match for it too...
Old May 21st, 2012, 03:16 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Where at ?
Old May 21st, 2012, 07:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by airbornrover View Post
Where at ?
The 109? Behind Barnstormers in Rumson. I'm pretty sure the owner of the building owns it - think he said he had it for years and wants to restore it at some point - but it's been sitting there for a while now. Also a 4 door Toyota Land Cruiser - FJ60?
Old May 23rd, 2012, 06:54 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
HAHA that's not often heard around here!
glad to help. Should have said somthn about the fuel lines. I've got all that stuff too!
Have fun with it.
Matt Browne
Old May 24th, 2012, 08:39 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I'm 2 silcone hoses and an air filter canister away from having this swap done... should be here by tomorrow
Old May 25th, 2012, 11:00 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That's great Adrian - can't wait to hear it.
Talked to the owner of the 109 seeing if he wanted your old motor for it but he said he's got too many car things going on as is. The 109 needs a bunch of love - chassis is for shit but I was daydreaming of new chasis, your 2.5 diesel, and a nice big garage and a ton of time.
Old May 25th, 2012, 02:09 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Hahaha. Do it! I'll be glad to help turn some wrenches whenever I can. I'll get to work on a truck that I dont have to pay for. It will be great lol
200tdi, 90, d-90, tdi
Swap 200 Tdi woth a BMW or Mercedes engine lakis Defender Technical Discussions 20 December 13th, 2015 11:37 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
How I can swap 3.9 to 4.6 in 95 D-90? Vadim Defender Technical Discussions 11 September 12th, 2004 11:30 PM
TCase Swap Doug For Sale - Parts 5 June 10th, 2004 07:51 PM
