200tdi oil leak - Defender Source
Old May 7th, 2014, 11:22 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
200tdi oil leak
ID:	94353I am so glad that I am anal about the maintenance of my engines, doing a timing belt on the new to me 200Tdi powered disco.
Front cover off and found an unwelcome sight, black sludgy mess even the belt had a track in the crap.
Removed the belt case and found after much cleaning the crankshaft oil seal has a 3mm cant to it. leaked from day one of a so called "reseal" not really sure what reseal means?
But never take anybody's word of just done that! that engine was running on borrowed time
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
200tdi, tdi
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
200tdi oil leak timing belt tens pulley pivot kjva Defender Technical Discussions 5 September 28th, 2011 03:18 PM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
