200Tdi into 109 - Defender Source
Old August 13th, 2011, 11:29 PM
200Tdi into 109
Hi All,
Some of you know that I started RedSq's (my 1960 109 SII LWB) engine swap over to a 200tdi this past weekend. Here is a link to a facebook album of photographs of the work so far. I think everyone should be able to see it.
http://tinyurl.com/3tmp9ab
Cheers
Dave
Old August 14th, 2011, 01:02 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Looks good... what are you going to do with the turbo?
Old August 14th, 2011, 09:33 AM
Hi Andrew. Was planning to move the turbo using a schedule 40 elbow and some flanges. I also bought a set of defender manifolds and turbo on ebay uk. Not really sure what I am going to do but will have a better idea once things start coming together.
Old August 14th, 2011, 10:00 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Looks interesting, I'll be watching.
It might though if you were drinking more appropriate stuff.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 14th, 2011, 09:03 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Nice work Dave - I thought you had all but given up on the Red Square with your cushy new 300 Tdi D-90.
Firemanshort
1980 Stage One 109
Sterling, VA
Old August 14th, 2011, 10:54 PM
I'm too deep in the hole with that thing to give up on it
Old August 15th, 2011, 08:21 AM
LOL. Looking good man!
Originally Posted by pendy
I'm here for the D's
Old August 15th, 2011, 06:38 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Hey, nice job on the timing pin thingy.
I have been scalloping out the cross member and welding in a section of tube....similar to the modification for frnt driveshaft clearance on SOA conversion. Allows the use of standard tooling.
I might like your idea better.
Matt Browne
Old August 15th, 2011, 08:02 PM
Thanks, yeah, I didn't want to do all that to the chassis. Especially since I have a habit of re-arranging those crossmembers...
Now I do still need to figure out how to make a useable drain plug. Hoping there is enough room to get the factory plug in and out.
Old August 16th, 2011, 01:16 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I think the defender manifolds will work with a lot less fuss, you were lucky to find them.
Mike Hammond
Old August 16th, 2011, 07:14 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I took a pile of steering conversion photos yesterday and now cant find the damn cord for the camera to get them loaded........and my card reader seems to be non functional.........hopefully shopgirl can get it sorted and up on the facebook.
Matt Browne
Old August 16th, 2011, 07:46 AM
Thanks Matt, I'll look for 'em.
Mike, I have been surprised at how often the defender 200tdi stuff comes up on ebay uk.
Old August 16th, 2011, 11:20 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I agree! But I have a 200tdi defender motor and that boss is still blank... if there is a notch in the flywheel what models had that hole (just curious??)
Old August 16th, 2011, 01:37 PM
there isn't a pre-existing notch. but there is a pair of hash marks. I'm pretty sure my 5 bearing 2.25 petrol had a plug in that location and have since seen a few photos of 200tdi's with one as well. You can really make the hole anywhere since you are drilling your own hole for the pin. I was a bit concerned about upsetting the balance of the flywheel but i decided that the amount of metal removed was so small and the amount of imbalance created would probably be no more than that caused by the clutch pressure plate being bolted on any which way. I could always drill another hole 180 degrees out, but that is just getting a bit beyond "Ren good"
I was a bit bummed that I got the thread pitch wrong. Anybody know what the proper thread is for these flywheel housing plugs?
Old August 16th, 2011, 02:57 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Isn't it BSP?
Old August 16th, 2011, 04:02 PM
I tapped mine to 1/4" BSPP and I couldn't even get the original plug started in the hole. The 1/4" BSPP plug from McMaster Carr fit perfectly.
Could be metric or maybe 1/4 NPT. Dunno...
Old August 16th, 2011, 04:45 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Do you have a thread gauge?
JL
Old August 16th, 2011, 05:12 PM
so what the flywheel locking tool wont thread in ? Thats the only reason you went to this trouble right ?
Old August 16th, 2011, 05:13 PM
Somewhere...don't know if it has one for 19. Or the metric pitches. I've been pretty successful with figuring out threads by other means. On this one I just ass/u/me(d)
Old August 16th, 2011, 05:15 PM
Was that a Canadian bitch slap ?
109, 200tdi, hammer toe, tdi, toes
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Spotted a 109 waveridin1959 Misc. Chit-Chat 5 May 18th, 2004 01:03 PM
1968 109 SW with Chevy engine kellymoe For Sale - Vehicles 0 January 27th, 2004 01:09 AM
