200Tdi into 109 - Page 2 - Defender Source
Old August 16th, 2011, 05:16 PM
the bushing/fitting that I used as a drill guide and the drill bit that made the hole are now the timing tool and have been tucked away in the kit with all the other timing tools. Which was always my "Plan B" all along so no real biggie.
Originally Posted by 130Tdi View Post
so what the flywheel locking tool wont thread in ? Thats the only reason you went to this trouble right ?
Old August 17th, 2011, 04:24 AM
JBinAlabama
john
Series 2A ..more parts on the way
Look'in Good!
Old August 17th, 2011, 07:09 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I'd prolly think about finding / making a regular steel pin 'cause if you snap a drill bit off in there you'll be bummin' and drill bits do snap pretty easily in that direction especially with the considerable force you'll get in that location with just a small slip at the other end.
Matt Browne
Old August 17th, 2011, 11:58 AM
oilburner's Avatar
oilburner
JL
large pile of parts
Was that a Canadian bitch slap ?
No way, just wanted to make sure he knew they existed. Dave's doing good.
Dave if you end up going power steering and you want a scout box I have 2 or 3 good ones.
JL
Old August 17th, 2011, 12:14 PM
He he yeah I know they exist. Have no idea where they are though
Have a P38 box already courtesy of Crazy Ray's.
Old August 18th, 2011, 02:37 PM
@ Matt, thanks for the tip about breaking the drill bit I should have thought of that. I'm going to order the correct size pin from mcmaster carr. let me know when you find the camera cable. In the meantime, got the proper mounts now so the engine is setting in place. I am concerned about the clearance at the front axle to crank pulley and have a few ideas about that. Pretty sure I have the crank pulley from my 5 brg. 2.25 so may try that. Also have toyed with trying something I have wanted to do for a long time, extending the spring hangers down an inch or two to mimic the placement of the MOD/1 ton suspension. Curious to see if anyone has done or tried to do that and what advice they have to offer. I wonder if parts exist for that. Guess I could hack my frame and just drop mine whatever distance I decide...hmmm...
Old August 18th, 2011, 04:16 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I have a set of factory 1 ton spring hangers that I carefully removed from my old frame. If you remove your stock pieces carefully and they are not hacked and your frame is not a rusty POS I would do a straight swap. The XMOD hangers are a waste on my spring over. I am going to be welding them on in September so if you want to do this, it would have to be rather quickly.
JL
Old August 18th, 2011, 04:35 PM
I'll send you some email
Old November 27th, 2011, 09:50 PM
Posted some updates on facebook. Have done a bit since august but did lose a few weeks to bad weather and a broken toe:
http://tinyurl.com/3tmp9ab
ID:	44182   Click image for larger version
Old November 28th, 2011, 07:59 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Have done a bit since august but did lose a few weeks to a broken toe
This thread is worthless without pics or at least a cool story.
Semper Fi!
Old November 28th, 2011, 08:22 AM
Looking good Dave. But I thought this was a little more plug and play than this. Are there any specific factors contributing to the amount of fab work and other adjustments needed?
Originally Posted by pendy
I'm here for the D's
Old November 28th, 2011, 09:58 AM
Thanks Charles. The only plug and play part is that the chassis mounts are in the correct place. Everything else requires some kind of fettling to make it work. But, so far nothing extremely difficult. Notching the center crossmember was a bit nerve wracking to make the first cut.
Most of the complications result from it being a LHD truck and being a 109 which has a taller frame section than an 88.
@wolf, the broken toe was already addressed in the NOVA HH thread
Old November 28th, 2011, 10:04 AM
Wolf Fabrication
Sterling Archer
'08 D3
Please. I don't read that thread anymore because all it is is Pedro claiming to show up and then not showing up, and Gustavo wanting to host a pool party at his house.
Oh crap, just found your toe! Nice one. In honor of your toe, I shall make it my avatar.
Semper Fi!
Old November 28th, 2011, 10:10 AM
LOL.
Way to keep the thread on toe-pic
Old November 28th, 2011, 11:38 AM
Wolf Fabrication
Sterling Archer
'08 D3
Okay, that was gross and only lasted a few hours.
Back on toe-pic.
Semper Fi!
Old November 28th, 2011, 01:56 PM
Yeah, that was not a very good idea. Even I was grossed out and it was my toe. Thanks for ruining my thread.
Back on toe-pic.
Old November 28th, 2011, 02:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
I didn't ruin it, I just spiced it up a bit. It was boring anyway. Now get back to work and post more updates.
Semper Fi!
Old November 28th, 2011, 02:12 PM
This thread was just good before. Now it's Toe-riffic!
Old December 30th, 2011, 03:12 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
So what's new?
Mike Hammond
Old December 30th, 2011, 05:45 PM
Spoke with Ren this afternoon. He's just ordered the specialty exhaust parst from Steven Parker in the UK.
109, 200tdi, hammer toe, tdi, toes
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
109 Galvanized Frame Coiler For Sale - Parts 1 December 29th, 2005 11:53 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Spotted a 109 waveridin1959 Misc. Chit-Chat 5 May 18th, 2004 01:03 PM
1968 109 SW with Chevy engine kellymoe For Sale - Vehicles 0 January 27th, 2004 01:09 AM
