110 door rebuild - Page 4 - Defender Source
Old March 19th, 2015, 05:23 PM
Wow, just wow.
Old March 19th, 2015, 10:03 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Originally Posted by cbfritz_03 View Post
Z, I didn't say they were easy? They can be highly frustrating and I was attempting to be supportive of Jason. I always encourage people to try...be undaunted by setback. I'll hush up ...don't want to derail this thread just cause I'm a cheerleader. Go Jason and your door building self!!
ok all done
Thanks Carmen, I usually try to do everything on my own. If you don't do it you won't learn
------ Follow up post added March 19th, 2015 09:08 PM ------
Originally Posted by Mybluett View Post
Strangely I consider doors a consumable - 15-30yr lifespan if cared for - but at some point it becomes less expensive and time consuming to let them go and replace with new shells… Move the guts over, replace the rusted channel and start the clock again.
Didn't find the original door build video - just the sound reduction and LaSalle initial door card fitting one.
I can't play the video on my iPad. What did you use for soundproofing? The steel skins sound like a damn tuning fork when you tap them with something. I'm thinking some kind of spray on stuff so I can get as much coverage as possible
Old March 19th, 2015, 10:09 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'm not trying to dissuade you from building your own doors Jason; just allocate a good amount of time to do them correctly. I've watched plenty get built and can honestly say it takes some skill.
Old March 19th, 2015, 10:14 PM
Go with stick on acoustic matting if you can. The spray stuff works but the mass loaded vinyl works much better. The only place I would spray stuff would be in the exterior of the wheel wells, the underside and any place I couldn't stick on a sound deadening product.
Old March 19th, 2015, 10:17 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Wow, everyone's getting all touchy. I can clearly see the complexity of the project and I am ready to take it on. The biggest problem is i have to do one at a time and switch them over sice I am re using the guts. Or I can just drive around doorless
Old March 19th, 2015, 10:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'm not touchy over here
Good luck!
Old March 19th, 2015, 10:40 PM
cbfritz_03
Carmen
none
You betcha... ...I agree and me too.
Old June 2nd, 2015, 09:24 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Any updates?
Old June 2nd, 2015, 10:22 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I just purchased a rear safari door from SP in the UK with a whole bunch of stuff including rear glass and a spare tire carrier and shipping was 100GBP total! Very pleased!
I also have 2 painted NTO Puma stripped doors that I have to swap out...having worked in assembly plants, if you are doing it yourself, put the hinges on and then just the latch with a string attached to the release...much easir to lift empty doors and mount, then install the guts once they are on the vehicle...put some tape on the door opening so there is no scratching....now if you have a helper, build the doors up fully and then bolt to the body...
Now is a great time to add door lock actuators and power window kits to the regulators...if of course you have push button and wind up windows...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old June 7th, 2015, 11:28 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Originally Posted by EnduroPro View Post
Any updates?
Skins are on and ready to go. I took one of the second row doors apart and realized I needed a few more parts like the fixed window bracket, totally rusted, and a couple of other small bits. Headed to Cabo next week so I am planning to dive in when I get home
Old June 8th, 2015, 12:45 AM
RBBailey
RBBailey
1965 IIa
Brian, I've often wondered about that these last few months.... considering that my Defender doors feel like wet newspaper even compared to my split, original 1965 IIa doors.
The IIa doors have 30% coverage of matting, and they are quieter, but mostly, the stuff actually makes the doors work better. Can I expect something of the same results when I use this stuff on Defender doors?
Project:
1965 IIa SWB
Old June 8th, 2015, 11:34 AM
Nicely done! The results will last for decades...
Old June 12th, 2015, 09:30 AM
curry's Avatar
curry
brandon curry
Series 1 and 110.
Nicely done. Cant wait to see the rears.
1983 110 rebuild...sort of... Gkase Truck Build-up's & Restores 83 March 18th, 2017 08:16 AM
Series door top rebuild cgalpin Series Technical Discussions 31 March 28th, 2013 12:35 PM
Topless 110 Rebuild SafariHP Truck Build-up's & Restores 73 June 17th, 2010 12:36 AM
Read door rebuild hinge kit Image needed ini88 Defender Technical Discussions 3 November 7th, 2006 01:12 PM
nice 110 rebuild on ebay Campbell Misc. Chit-Chat 6 July 14th, 2004 07:28 AM
