Yet another LWB to wrench - Page 3 - Defender Source
Old December 3rd, 2012, 10:12 PM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
Don't shoot the messenger
Old December 7th, 2012, 05:52 PM
Tune up with new cap rotor plugs wires. Screaming Marelli switched out with relatively fresh alternator from the now-donor green LooB. Installed NRP exhaust from same vehicle; old one was full of rust.
Tomorrow: Brakes, and switch drive shafts from old truck.
Old December 8th, 2012, 09:38 AM
Sounds good Bill, but it sure makes me wonder if fixing the other one wouldn't have been easier!
Originally Posted by pendy
I'm here for the D's
Old December 8th, 2012, 06:41 PM
Done with all the hit list from the inspection.
No, fixing the other one would have definitely not been easier.
Old December 18th, 2012, 09:32 PM
Got perm registration today. Took it for it's first long-ish drive over to the Eastern shore. A couple things came to light.
1. Drivers mirror about fell off. Seems PO had it in place with two loops of electrician's tape. Swapped out for good one.
2. Getting a liitle swoopy steering. I guess I need to check all my bushings and rod ends, but I suspect it's the frame bushes for the radius arms and trailing widgets.
3. Bucking at speeds over 65. Could be a bad module, a vacuum leak, some shiz, I don't know but it's annoying. Might try moving the known-good stuff from the other truck over and see what happens.
Old December 18th, 2012, 11:11 PM
On #2 I would bet on panhard rod bushings if the ball joints are good (I assume you would have noticed torn bushes while under it) and swivel preload is ok (this seems overblown to me but ....)
lwb
Tip: 32mm fan wrench kolvedic Defender Technical Discussions 4 September 26th, 2005 08:51 PM
Lug wrench - do they really shrink?? paulb Defender Technical Discussions 4 June 26th, 2005 01:42 PM
I need some advice- RR LWB surfd90 Defender Technical Discussions 3 February 23rd, 2005 02:11 PM
Oil Cooler Line Wrench Size? Sergeant_V Defender Technical Discussions 5 December 19th, 2004 03:02 PM
'93 Range Rover LWB tbmcneill For Sale - Vehicles 2 January 8th, 2004 01:36 AM
