World's First - '71 Series IIa w/ Chevy LTG & T56 6-Speed - Page 3 - Defender Source
Old July 19th, 2017, 10:15 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Originally Posted by CircuitTested View Post
We had the front & rear shafts custom made. We used the stock flanges and u-joints but had the front lengthened and the rear shortened a touch. We ended up really close to the stock location but did have to notch the front cross member as the t-case ended up being lower.
That should be no problem because with the hockey puck mounts there is very little movement... unless you use some other mounts.
RDavisinVA
Old July 20th, 2017, 07:12 AM
Contractor's Avatar
Contractor
Will
1969 IIA
Great build, looking forward to more posts.
Old July 20th, 2017, 05:47 PM
CircuitTested
1986 Defender 90
Was able to use the stock hockey puck mounts...super simple!
1986 Land Rover Defender 90 //
Old August 1st, 2017, 12:59 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
litter of possums request...
Old August 1st, 2017, 01:55 AM
Chris B
72 + D1 drivetrain =?
If Forbyn makes a 1.6 ratio rather than 1.2 TC, that might save the trouble of replacing the R&P.
Old August 1st, 2017, 07:35 AM
LR Max
Thomason, Max
1973 Series 3 109
Ok I like this.
Quick search shows they put these engines in Impalas and Malibus. Good used engines are plentiful. That said, finding a wrecked car would be better since you could get all the wiring bits, cooling, throttle pedal, etc.
Transmission, I'd bike the bullet and get new. Also get the GM crate version. It has the "low" 1st gear and then the ridic high 6th gear. That said, I haven't run the numbers on how all that would pan out RPM wise in a series.
But yes. I really like this and I think this is a good solution for engine replacements in series trucks. I've been eyeballing the newer chevy V6 engines, but this will work very well.
What I like about these newer engines, the power steering pump, AC compressor, etc is all there. And it puts out the HP you want without any issues. Heck, you should PROBABLY REDUCE the output. But that is just silly talk.
Old August 1st, 2017, 03:15 PM
CircuitTested
1986 Defender 90
https://youtu.be/FDHaP7m5Z3A
Quick 0-60 (ish) run. Totally open intake. Turbo whine!
Old August 1st, 2017, 03:51 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
That's pretty insane for a Series!
Old August 1st, 2017, 03:59 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Cool
Holy overkill! I wonder what it would be like without the turbo. Don't think I need to go that fast in a Series. Cool tho for sure!
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old August 1st, 2017, 04:12 PM
CircuitTested
1986 Defender 90
The real shocking part is how well this thing handles at speed. I was pretty nervous about it since I've never broken 45mph in a stock Series but it's way, way more planted than I expected. I can't say I've gathered the fortitude to power slide it around a corner yet but its definitely possible...
------ Follow up post added August 1st, 2017 04:14 PM ------
4.7 gearing is stock in the Salisbury so it actually saves you from having to re-gear the diffs.
Old August 1st, 2017, 05:27 PM
Chris B
Follow up post added August 1st, 2017 04:14 PM ------ 4.7 gearing is stock in the Salisbury so it actually saves you from having to re-gear the diffs.
I totally forgot that you're using it up from a series. So of course you'll have those gears....
Old September 30th, 2017, 11:25 PM
JacIntyre
Sean
1970 Series IIA, 109 Coiler
Scott, You wouldn’t happen to know if the earlier LTG versions found in Camaros and the Cadillac CTS are similar dimensions?
Old October 1st, 2017, 07:55 PM
CircuitTested
1986 Defender 90
Similar dimensions, yes. However, the internals are different and some annoying things like the bellhousing bolt pattern were changed from Gen II to Gen III LTG motors. Additionally, I don't believe GM sold the earlier LTG motors as a crate option and the wiring situation might be tricky since you'll have to use the existing harness/sensors/ECM, etc. Let me know if you need anything more specific.
Old October 1st, 2017, 08:57 PM
cowboy
steven
So how's it coming? - when can hundreds & hundreds of us begin dropping by for a test drive?
Old October 1st, 2017, 09:08 PM
CircuitTested
1986 Defender 90
She's done! It's at the shop now for a 500 mile check up, oil change and to have the hard top installed. If you're close come stop by this week and check it out for yourself. We did a proper photo shoot last week so I'll be posting some pictures this week.
The little 4 banger is a great motor. Reserved and docile at light throttle but if you bury it, hold on. We were power sliding the truck around some long sweepers at 50mph. We put together a formal retrofit package for some local Series owners so if anyone was thinking about the conversion just give me a shout and I can walk you through the whole thing.
Old October 1st, 2017, 10:05 PM
defenderholty's Avatar
defenderholty
Russell
1985 LR Ninety 200tdi
Man what a great idea. I bet that would be a good powerplant in old 2.5na defender. I like the idea of less weight up front. It does better off road.
Old October 1st, 2017, 11:30 PM
JacIntyre
Sean
Thanks Scott. That was the info I was looking for. I’ll start looking for the newer one then. I’d be interested in hearing about the formal package in more detail in the mean time. PM is fine if you’d rather.
Old October 2nd, 2017, 05:29 PM
CircuitTested
1986 Defender 90
Final routing of intake plumbing. Hidden under passenger fender is a GM OEM style air intake box. Minimal turbo whine. Total sleeper.
Old October 2nd, 2017, 05:35 PM
phoenix37's Avatar
phoenix37
john
Looks great...well done.. speaking of whine..how do you like the Forbyn case? How does the gear whine compare to a series or lt230?
Old October 2nd, 2017, 05:42 PM
CircuitTested
1986 Defender 90
I with the unit was a bit more plug and play out of the box but it's certainly a beefy unit. Whine wise, it's not noticeable and it'll take any amount of power you need. Some Atlas t-cases we've seen in some big dollar trucks are way, way noisier...
series
1970 Land Rover Series IIa $18,900 Mike Sandone For Sale - Vehicles 2 June 24th, 2013 07:00 PM
'71 Series IIa - $6,500 Winston-Rover For Sale - Vehicles 15 August 25th, 2009 12:43 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
