Whats the latest on strong axles? - Page 2 - Defender Source
Old April 24th, 2013, 01:49 PM
That does not help you in the front axle. The weak bits are all the same as the Rover axles.
Old April 24th, 2013, 01:52 PM
Also, upgrading a rear Sals to 35 spline is not simple or cheap.
Old April 24th, 2013, 02:02 PM
I think all those clapped out snatches are RHD, so if you need a LHD Sals front, well, good luck finding one.
Old April 24th, 2013, 03:02 PM
RoverC
Cliff
1997 D90 ST
If they are using Currie axles, wonder what diff they are using? Curries says a max of 400hp - 450hp on their high pinion diff. Im at that or beyond. I was wanting a high pinion.
I liked the Ashcroft setup, but hearing they have already stopped making it proves my point about replacement parts.
The reason I went Chevy w/ a GM auto is to be able to buy any part needed just about anywhere I go. These are so reliable I doubt I will need anything, but if I do.....
I used the LR t/c built by ashcroft and if it breaks Im sure someone here could provide what I need.
So the axles would preferably be some sort of American made with readily available parts should the worst happen.
Was hoping some company had already done them so they know spacing, mounts etc.
Old April 24th, 2013, 03:44 PM
psykokid
Jake
1997 Disco
Dynatrac was making rear axle assemblies for NATO 110's via a contract with Ricardo. Not sure if they were doing the front assemblies as well. IIRC they are also doing the axles for a couple of defender projects so you might be able to get in touch with them and see if they could make something with heavier duty components that the standard rover stuff since they should have all the measurements and mounting points on file.
Old April 26th, 2013, 05:50 AM
EWR's Avatar
EWR
Carey
1954 CJ-3B
I don't know....I wheel with a few Heep owners. One in particular running a built Hemi in his JK. He runs 37" tires and a pair of Currie High 9's,...and he is WOT all the time. And a horrible driver to boot, and with all of his foolishness he has yet to break one. And I'm willing to bet he's much harder on his stuff than you(OP) are.
What tree?
Old April 26th, 2013, 08:55 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
60 front and 14bolt rears are a hard combination to beat for strength and are relatively easy to build.
The 9inch is also very strong and will have better ground clearance.
If you want to be able to walk into any parts store and get parts, go with the 60/14bolt combo. I'm running that behind a screamin chevy 383 with no problems. On the other hand I've had quite a few issues with my salisbury front that's running under my 109 with a Cummins 4bt. At this point I wish I had just gone with a dana 60 front under the 109 too.
Old April 26th, 2013, 09:48 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Have you done a search or posted on the LR forum on Pirate? Lane has some very interesting pics/words on his build: http://www.pirate4x4.com/forum/land-...9-build-9.html
I am running Toy stuff which is a nice upgrade still using the stock Rover housings but if you are going 400+ HP/TQ and 37s then I am guessing you will need some custom axle work done. It might be a good time to go coilover and have Anti-Rock sway mounts done too.
Old April 26th, 2013, 09:52 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Don, did you do the fronts yet? Would like to it when you do!
Old April 26th, 2013, 10:20 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Not yet - I am slow as shit - and have been sidetracked with all sorts of other projects. I do pick away at it and it is a nice piece of kit. The front will be an open diff but I think I will still benefit from the HD axles and CV's and the Toyota 3rd.
Old April 26th, 2013, 10:43 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Grabbed this pic of GP's FB page.... disks are modified RaRo with D2 calipers as there low profile & parts easily available. They also found that the input flange can be swapped for one of an LT230.... direct fit so no changing drive shafts
For anyone thinking of building some HD non-LR axles these looks a good way to go..... as long as you have the $$
axle
101 FC axles for sale Method PHX For Sale - Parts 18 March 24th, 2006 10:27 PM
35" MTR's, Wheels, Axles madcowdungbeetle For Sale - Parts 0 January 27th, 2006 07:28 PM
Who makes the strogest axles? Scott 9835 Misc. Chit-Chat 21 December 21st, 2005 01:02 AM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
GBR 4:10/ARB 3rds and Axles WhiteD90 For Sale - Parts 6 December 2nd, 2003 03:00 PM
