welding precautions - Defender Source
Old August 30th, 2015, 07:04 PM
doscazadores
Vic Stull
none
welding precautions
I've done plenty of welding on frames, etc., but never on a vehicle with an ECU. I've heard precautions should be taken; heard go ahead and weld away. Have a little weld project on '95 D90 and just wondering what your experience has been. Disconnect battery sufficient to avoid any damage?
Thanks, people.
Vic
Old August 30th, 2015, 07:11 PM
87 D110 (Ruby)
Disconnect battery
Old August 30th, 2015, 07:17 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by doscazadores View Post
I've done plenty of welding on frames, etc., but never on a vehicle with an ECU. I've heard precautions should be taken; heard go ahead and weld away. Have a little weld project on '95 D90 and just wondering what your experience has been. Disconnect battery sufficient to avoid any damage? Thanks, people. Vic
I've done a lot on welding on trucks with ECUs and never had an issue. With that said, it's better to be safe than sorry and disconnect.
Semper Fi!
Old August 31st, 2015, 10:37 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Do your best to set it up so the welding current flows from the arc through the piece you're welding and to the ground clamp. Not from the arc then the long way round the body and chassis to the ground clamp.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 1st, 2015, 12:34 AM
Tarheeld
Bill
1985 110
Also have decent and multiple fire extinguishers, that are PRIMED, nearby.
Booger welding o2batsea Misc. Chit-Chat 9 March 23rd, 2010 06:13 PM
Welding thin aluminum air condintioning tubing? Davis Defender Technical Discussions 5 January 9th, 2010 06:38 PM
Welding equipment paul64 Defender Technical Discussions 28 July 20th, 2009 02:55 PM
Safety precautions for ignition coil maintenance chris snell Defender Technical Discussions 3 February 13th, 2009 04:04 PM
welding diff guards rover4x4 Defender Technical Discussions 6 March 26th, 2006 03:50 PM
