VDO Vision electric speedo - Defender Source
Old May 15th, 2013, 11:09 AM
willr's Avatar
willr
WILL RAGSDALE
NONE
I am swapping out my gauges on my 110 and I want to replace my speedo with an electric VDO vision speedo. I am trying to get some guidance on how to swap the old mechanical speedo with the newer electric VDO speedo.
Old May 15th, 2013, 11:13 AM
BEIS's Avatar
BEIS
RYAN BEIS
D110 Soft Top with full rollcage
I will be watching this thread. Would like to do the same thing to my 110.
Are these the correct VDO Speedo options?:
1) Mechanical: http://www.egauges.com/vdo_mult3.asp...ockpit&Units=E
2) Electronic: http://www.egauges.com/vdo_mult3.asp...ockpit&Units=E
-Ryan
Old May 15th, 2013, 11:20 AM
There are threads on this already. Do a search.
You need a 4" gauge so that one linked is not suitable.
Old May 15th, 2013, 11:26 AM
BEIS's Avatar
BEIS
RYAN BEIS
That's fine. Will, let's just PM each other and not post in a completely open forum for advice.
-Ryan
Old May 15th, 2013, 12:52 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm sure he didn't mean to be a jerk about it but there is a huge "Merged Thread" that details all the info on the VDO Swap for the Speedo as well as all the other gauges. There are some really great write-ups and misc. info that will never be duplicated in a new thread...
See These:
http://www.defendersource.com/forum/...&highlight=vdo
Old May 15th, 2013, 01:23 PM
I'm sorry if you found my reply terse. I was on my phone and could not search and link for you with the phone app. It seems reasonable that you should be able to search a topic of interest by yourself.
In addition to the threads noted above there is also a tech article written here: http://www.defendersource.com/tech/s...placement.html
If you have any problems or specific questions, please let us know.
Old May 15th, 2013, 01:27 PM
The speedo needs to be a 4" electronic unit. The VDO Vision series is the best choice IMO. These are available in a few different dial choices. There are also full metric versions (not available at egauges). http://www.egauges.com/vdo_mult3.asp...Vision&Units=E
The "Cockpit" series uses reflected dial lighting and is not as nice to use as the "Vision" through dial lighting.
Old May 15th, 2013, 04:45 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I always wondered what the difference was between the two! Thanks!
By the way...I haven't used the Emoticons in a while....HILARIOUS!
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
VDO Speedo help timtimtj Defender Technical Discussions 6 October 24th, 2010 10:16 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
VDO speedo for sale vlocci For Sale - Parts 2 January 9th, 2004 11:32 AM
