Unwanted/Needed Restoration Project - Defender Source
Old October 8th, 2007, 11:17 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
This is where I'm supposed to write something witty and funny; or something.
Old August 26th, 2015, 02:30 PM
RickM
Rick Mabus
95 D-90 ST
Hello all. I am new to this area of the forum, but not new to the forums. I have some specific questions but I might introduce my truck if that is ok. I purchased a yellow 95 d-90 in 2001. It was my daily driver for the longest time. Then it sat for a really long time, then I drove it again for a short time, and about a year ago I pulled it into the garage for the pretty days. Anyway, I found that as a daily driver it was one dependable beast. As a garage queen it sure does give me more trouble. I will post pics soon, and will post pics as time goes on with this, but recently I started to notice some paint damage, and I had leaks under the hood. So it started, and this is what has been done.
1. Newly painted front end
2. New top
3. New wheels and tires.
4. Winch Bumper/Winch
5. Onboard air
6. Front end bushings (I think all of them)
7. Fuel pump/Regularly known parts to fail/routine maintenance.
Things plan to address.
1. Steering Box
2. Steering link.
3. Interior plastic/Rubber.
So here are some questions. My dash and door panels are failing. I actually am simply planning to replace all the rubber on the floor and whatnot with stuff from Rovers North, like the trans tunnel etc. I think the dash parts should be fairly reasonable also, but the door cards. Wholly Crap. Those are expensive for what they are. I was thinking about making my own. Anyone have any experience taking some sheet aluminum or something like that and making a pair of door cards. This should also allow for some more speaker room!! Lastly I also have noticed my upper cable for my speedo is gone. Rumor has it those are hard to find. Anyone have a fix for this?
Old August 26th, 2015, 07:10 PM
Landy_Andy's Avatar
Landy_Andy
Andy
A good option for the doors.... and interior panels in general are those from LaSalle Trim
Door Trims :: LaSalle Trim
Not sure who imports those or if you need to go direct, am sure one of the other guys will know.
Old August 26th, 2015, 07:28 PM
Upper dash pad is still available from Land Rover (genuine), I had mine shipped to my door direct for ~$210 from landrovermerriamparts.com
I had/have plans to do updated ST door cards out of aluminum available to the masses, but admittedly that is probably still a bit down the road .
Old August 26th, 2015, 08:16 PM
Ignotus
gene
1960 109, w/200TDI
There are other suppliers than RN. Goooooooooooooooooooogle is your friend. I like to use this UK based search engine; Land Rover Workshop
There was a recent thread on making/buying Defender door cards.
Gene
1960 109
1960 88 Ignotus
Blog;
Old August 31st, 2015, 11:40 AM
RickM
Rick Mabus
95 D-90 ST
So this weekend, I did the steering box swap, and also did the Ujoint swap on the steering shaft. The trucks drives like a dream now. I am more motivated than ever to get this thing cleaned up and presentable. Nathanwind. I just used your group to actually order all my dash components to start that project. My speedo is not working right now, so this needs to get done for that reason alone.
Here are some pics of my rig.
Old September 11th, 2015, 09:11 AM
RickM
Rick Mabus
95 D-90 ST
Landrovermarriam is no longer able to get a lot of the parts for this stuff. They also are not the best at the customer service game.
That said, I am back to square one on the dash parts. I will see what I can come up with.
Old September 11th, 2015, 09:21 AM
SafariHP also has the dash parts you're looking for I believe.
Old September 11th, 2015, 09:24 AM
Whoa...that's a bummer. Did they have the top dash pad? I ordered that from them just a couple months ago when I swapped it to the newer style and had no issues at all (and their price was hard to beat).
But yes, check with Bryce or Stephen @ SafariHP as Josh mentioned - good folks.
Old September 15th, 2015, 10:51 AM
RickM
Rick Mabus
95 D-90 ST
As usual you guys have come up big for me. I talked to the guys at SafariHP and I have parts on the way. I did not realize that they made an instrument cowl out of alloy. Mine was broken when I got this truck in 2001 so this will be a perfect upgrade. I also ordered the other dash parts to boot. Door Cards are on the way. I am going to try and tackle all of this carefully while attempting to not damage my speedo cable connection any more.
Old October 8th, 2015, 02:20 PM
RickM
Rick Mabus
95 D-90 ST
No real progress to report, but I have gotten a bunch of parts in to start this project off. One thing I did order were the door cards from IG4x4. I may have some fitment issues but I a going to get started and see where things go.
Old January 8th, 2016, 10:50 AM
RickM
Rick Mabus
95 D-90 ST
Has anyone ever used Dynomat as an insulation barrier, and then put down a roll down bedliner over it? My though is that the Dynomat may act as a heat barrier, and then also act as a bit of a helper to not have the bed liner be so permanent.
Old January 12th, 2016, 10:48 PM
It sounds like a waste of a lot of money to me.
Old January 13th, 2016, 03:53 AM
The three piece rubber mat set that is sold is great. Use that. As is the TD5 style seat box cover (if you can find one). No need to go with dynamat and bedliner. Not a fan.
restoration, wanted
Project Blizzard 1985 110 Full Restoration SafariHP Truck Build-up's & Restores 11 October 22nd, 2014 06:31 PM
83-87 Defender 110 Restoration Project Wanted jeffrabhan Wanted 9 January 19th, 2014 05:37 PM
Another "It Wasn't Supposed to be a Restoration" project Axel Truck Build-up's & Restores 18 December 29th, 2012 08:20 PM
My daily driver turned restoration project RickM Defender Technical Discussions 10 January 26th, 2012 10:24 AM
Restoration of 1993 NAS D110 Needed Jon_Winningham Misc. Chit-Chat 21 January 29th, 2008 11:27 AM
