Tub question.. - Defender Source
Old May 11th, 2014, 03:44 PM
cbfritz_03
Carmen
none
Tub question..
I was looking at the tub and thought there was a piece of diamond plate on top of the tub floor. On closer inspection it looks as if the diamond plate is the floor. Is this correct? ...and should there be any concern that the tub will wrack when I hoist it off? Just trying to be careful. Any advice would be appreciated.
Old May 11th, 2014, 10:24 PM
cbfritz_03
Carmen
none
Its not diamond plate from the factory. It has been added.
As for it racking, take diagonal measurement ahead of time, then match them on reassembly. Be aware though, these things are not very precise from the factory.
-Jeff
It looks that way too. Has been riveted down onto a frame of angle iron underneath. I don't mind the look of it and it is really sturdy. Whoever did it did a good job.
But I still have to address the rust, so out it goes.
I will do that. I remember reading how they were pretty wonky and getting them near square is a challenge.
Is this part of the reason for the discussion of the washers? I found three on one side and two on the other.
Thank you Jeff.
110 rear tub question Tyler Wirken Defender Technical Discussions 4 September 22nd, 2010 11:14 AM
Series tub vs 110 tub MUDSUX Defender Technical Discussions 7 March 4th, 2010 10:50 AM
NAS 110 tub $700 obo or will trade plus cash for 110 pick up tub evilfij For Sale - Parts 12 December 21st, 2009 05:26 PM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
Rear tub restoration question Hoosier Defender Technical Discussions 1 September 5th, 2006 08:29 AM
