The end is near - Page 6 - Defender Source
Old December 7th, 2004, 01:18 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It's all about you isn't it Mike? That will have to wait till I have the front end on. One thing at a time. I have a plan though, possibly a great plan. The only possible thing that could get in my way is physics.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 7th, 2004, 12:54 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
No no no, this thread is about you & your truck
My 90 died & D'Ho clutch slip is about me
Anyway those axles look awesome. do they have CV joints or UJs?
Don't let a little physics get in the way of a cunning plan..... whats the worst that could happen?
The universe implodes?
Mike Hammond
Old December 7th, 2004, 10:26 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
UJ's and 1.5in Cromo Axles Yes, the end of the universe is imminent if this intercooler does not work out. Well see, I have will have more pics shortly.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 8th, 2004, 11:35 AM
mikeslandrover
Mike Hammond
I didn't think UJs were so good with permanent 4WD. won't the steering wheel jump about on full lock?
Mike Hammond
Old December 8th, 2004, 09:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
No, thats a total myth started by the Global Warming believers. Joking aside, I have no idea where that came from but there is no truth to it at all. Besides, I do not have Rover ends anymore which means I will have selectable locking hubs. I can run in 2wd and 4wd. The bummer with this is that in 2wd I will feel the effects of the rear detroit that I could not tell I even had before.
Hey Tis,
Where in the axle did KC mount the oil seal? I may have found out the true cause for the leak issue.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 8th, 2004, 11:07 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Sorry ... There isn't one... Seen it in person..
Hey Tis you need a machine shop? Shipping costs only..
Keith
Keith
Big, Red and ... aaa Red..
Old December 8th, 2004, 11:12 PM
damn even I have heard about the CV vs UV before. What t-case you got?
Old December 8th, 2004, 11:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"Sorry ... There isn't one... Seen it in person.."
Huh? If there isn't one how can you see it in person?
I have a 1.4 LT230. Hopefully soon to be a 1.2.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 9th, 2004, 12:56 AM
acid
Old December 9th, 2004, 09:49 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Keith, seals are coming out to you.
David- they sit near the outer ends of the axle, just inside the "C". I'm pretty positive it is the axle shaft oscillation created by the ujoint, particularly during turns, that is causing the leak.
What is your theory?
Tis
Old December 9th, 2004, 11:06 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Dave!!! Why i oughtta!!!! Always the comedian!!
Send them on out Johnathan I will turn them quickly... Literally..
KAK
Keith
Old December 9th, 2004, 11:59 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Tiz,
I was talking to builder about this again and he said he know exactly what the cause is. The seal is supposed to be mounted 3in from the diff on either side. What is happening is when the axle osilates on the turn it moves like .020 on the diff end and .200 on the U-Joint end. Basically, they were put in the wronge place. But, that Gasket might still work. Keith, I need to talk to you!!!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 9th, 2004, 12:33 PM
mikeslandrover
Mike Hammond
Tiz,
Ah that osilation will be due to the UJs not having a constant velosity when the road wheel has some turn on it.
The steering wheel on my IIA used to fight a bit on high traction surfaces in 4WD and I was told that this was due to the UJs in the front axle. Not a huge issue and not noticable 99% on the time.
So when you're on the road the transfer box will be in dif lock and the front hubs will be disengaged = read drive only?
doughnuts
Mike Hammond
Old December 12th, 2004, 09:18 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
More Update Pics
Coming along well now. The steering is left and there is some work to be done on the track bar but the hub is basically together with the new Rover bolt pattern. The new wheels clear those big old calipers by almost nothing. I like the stance, about an .75 in on each side wider than the rear.
Oh, and Mike, I did all the measurements and the intercooler option will not fin on mine because of the winch. There just is no room left to make a decent sized one fit the way I had intended. For you guys that have no winch in there, it would work fine. I can post up where and what to buy if you want. I have to go with a direct replacement to it looks like Twisted Performance in the UK is going to get too much of my money.
ID:	2064   Click image for larger version
ID:	2066   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 13th, 2004, 03:20 PM
mikeslandrover
Mike Hammond
Particularly with the exchange rate at the moment.
Bad for you. good for us if we want to import ftuff from the US.
I'd be interested in the intercooler details that you couldn't get to fit.
Not the one that was too big though
Those wheels/calipers look really heavy duty
Mike Hammond
Old December 13th, 2004, 04:43 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Nice work on the truck. But what I realy like is the car lift the truck is sitting on. I would give my left nut to have the space and money to put one of those in. You look like you are out near Santee from the looks of the boulders in the background.
Old December 13th, 2004, 08:56 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Very close, Ramona. Not my lift though, of course.
Mike, the intercoolers I was going to run are either standard E-bay fair or;
www.bellintercoolers.com
http://www.fluidcontrol.net/pages/faxspecs.html
These would both work depending on what you build around 120% better than the euro models.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 13th, 2004, 09:04 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I dont see a D-90 Source sticker on there.
Chris von C
[/size]
Old December 13th, 2004, 10:28 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Send me a sticker and I'll pimp the d-90 source!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 13th, 2004, 11:43 PM
« - | It's alive! »
Tilting Front end Feraltracker Defender Technical Discussions 20 November 26th, 2017 10:40 AM
Front End Shimmy bbandit Defender Technical Discussions 19 April 11th, 2006 11:06 PM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
