The end is near - Page 3 - Defender Source
Old October 14th, 2004, 03:02 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm no engine guru, & always willing to learn.
You probably can run higher boosts than 15psi, it just puts more stress on the engine.
The garage where I get most of my parts from was campaigning a 100" Landrover for safari racing a few years ago, it had the biggest intercooler I've ever seen and was putting out over 200bhp, the fuel pump was totally rebuilt with different internals and injected fuel by the bucketfull but the engine didn't last so long.
David I'd be really interested in knowing how you set up your EGT guage. Where does it fit? Was there much machining involved? Do you run a boost guage too?
I've heard that some people plumb the turbo waste gate activating pressure into the inlet manifold as opposed to its current position just after the turbo impeller, thus negating any pressure loss through the intercooler.
I'm hoping that only moderately tweaking the fueling & turbo boost won't do any damage.
The 90 is only slightly faster than my 110 now, it used to be a good bit more slugish AND it tended to use more fuel????? This was a cause of constant irritation to me.
Get that bigger intercooler in there David!!
Are the metal boost pipes on your truck standard or have you replaced them with ones without the constrictions in them, most of the intercooler companies over here do sets if alli pipes without the squashed bits in them.... what were landrover thinking of when they did that?
Mike Hammond
Old October 14th, 2004, 10:09 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Don't know if it will make much difference, but I do know alot of guys that race diesels use plastic wire ties around the intercooler pipes, so they don't expand, and you don't loose that small amount of boost from the turbo that you normally do.
How in the world have I spent this much money and still don't have a running vehicle?
Old October 14th, 2004, 10:21 AM
mikeslandrover
Mike Hammond
I've seen that done too and wondered about the validity of the idea. How much do the pipes expand?
They certainly don't blow up like balloons (well I hope not anyway). the turbo lag caused by the pipes expanding ever so slightly must be infinitesimal.
Mike Hammond
Old October 15th, 2004, 12:20 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I will get the intercooler hooked up as soon as I can. I think I can get a 3.5in thick one in there. I can take pictures of the egt guage but it is straight foreword. Just a nipple welded in the exaust and it fits in the standard 2 1/8 guage hole in the dash. Just + - and light power. I can't stress enough how important it is, you would not believe how much it can change, and you could be hitting 1500 and not even know it, I can only wonder what I did to the engine before I had the guage, even though it was stock. I don't run a boost guage, just no room left and I don't ever go over 17 psi. I did change the intercooler pipe. The stock one was nuts! My exaust guy made one for me for $15. Don't worry Mike, you won't do any damage, all you have to do is keep it below 1200 and you are fine. Now all I need to do is get the intercooler in and the propane injection and I am set.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 16th, 2004, 02:56 AM
mikeslandrover
Mike Hammond
Ah, propane injection, I've heard good things about that in the mags too! Briefly spoke to one chap who had a home made system cobbled together running off of a camping gas cylinder (somewhat illegal over here) and he was claiming V8 type acceleration with no other mods. What's the propane going to do to the EGT?
Mike Hammond
Old October 16th, 2004, 03:21 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hank Hill> "ah propane, the gas of the gods". I have not had first hand experience, but from what understand and have been told, the propane lowers EGT's. It allows 100% of the diesel to be combusted giving anywhere from a 10% to 40% gain in HP. I would imagine on 300TDi's the gain would be closer to 40% due to no computer aided injection. I am interested but it is down the road for me, it also improves gas milage by quite a bit.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 24th, 2004, 08:48 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Back on the end is near
Here are some project update pictures. This is the finishing process on the roll cage and front bumper. Have not got into the 60 stuff or tire carrier yet. These are only tacked into place. The front bar is resting on the running lights. That will go up and have another bar on top of it. The front will also have a pre-runner style bar with light tabs and there is still a lot to do to the cage. So far it is looking pretty ugly...perfect. And the winch has a much better approach angle than stock! The pics are low quality scans, sorry.
ID:	1693   Click image for larger version
ID:	1695   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 25th, 2004, 03:38 AM
mikeslandrover
Mike Hammond
Looking good.....what are you doing about a front bumper?
Will the standard wheel arches cover hose monster wheels or is that not an issue in the states.
Local bobbies get very bent out of shape if the wheels aren't covered by bodywork over here.
Mike Hammond
Old October 25th, 2004, 09:52 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I don't think I am going to run a front bumper. They are heavy and bulky and anything I bend up, I will just cut off. I am still contemplating building one but the cage would go in the same way since it is completely unboltable. The cops in Cali are pretty cool about the tires. I just hope they continue to be that way since the new frontend is going to stick out another inch!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 25th, 2004, 02:11 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Hey David
I think you forgot to install X-bars here, here, and here!!!
Sorry, I couldn't help myself.
DJ
Old October 25th, 2004, 02:57 PM
wow that thing is pretty well protected externally
Old October 25th, 2004, 03:07 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
DJ, you mean like this?
I had to. Don't you just love paint shop. David, ITs all love..
Legend in My Own Mind.
Old October 25th, 2004, 03:14 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
LOL... we can almost start calling the truck "Beyond Thunderdome". David, you are planning on wheeling that or just pushing it to the top of hills and tumbling down them? Hell remove a few body panels and add a few more bars and you'll have a full out rock buggy.
Randy because its a BMP file. the software can only thumbnail JPG and I think GIFs.
Chris von C
[/size]
Old October 25th, 2004, 03:46 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Bwhahahahahah!!!
Yes. Yes I DO!
DJ
Old October 25th, 2004, 08:12 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Oh my God! I'm really speechless! Dave what's your plan for this truck?
World traveler
Old October 25th, 2004, 09:26 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You guys crack me up! I am just really anal about rolling. My last truck I put it on its roof once and on it's side 3 times. I try to push things further than they are meant to go. When somebody says something can't be done, I try harder to make myself look like an idiot! So that being said, this cage is designed to take a fairly significant shock load, including going over backwards. It is also in the right locations to most likely make contact first. The running gear is strong enough to handle almost anything, leaving room for the friek ass crazy something. The only weak link is the Drive shafts which I am going to leave weak and carry a spare. It's almost done, and with no internal cage or front bumper, you would be surprised at the final weight. Also, I can still take the top off. I really wish at this point that I had more wheel base as that is really the only thing that limits where it can go. Maybe a bob tail and a lenthening is in my future... na.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 25th, 2004, 10:05 PM
Not to needle, but it would have been a lot cheaper to put Tdi stickers on one of these and run around in it wearing an AA Yellow jumpsuit.
Old October 25th, 2004, 10:31 PM
Rotflmao
Old October 25th, 2004, 11:57 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
My truck is NOT AA yellow.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 5th, 2004, 09:21 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
The first thing is remove the top cover and small pipe connected to the top cover by the banjo union.
Hey Mike, I know it sounds silly. But is it a common problem getting the four screws undone on the top cover? I'm having a hell of a time trying to get them backed out. They just won't budge and I'm quickly reaching the point where the heads are getting close to stripped (who puts a flat head screw there anyway?). I hit them with PB blaster last night and will see how it looks tonight. I'm probably going to pick up a impact driver on the way home too just in case. It's always the little things...
« - | It's alive! »
Tilting Front end Feraltracker Defender Technical Discussions 20 November 26th, 2017 10:40 AM
Front End Shimmy bbandit Defender Technical Discussions 19 April 11th, 2006 11:06 PM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
