Td5 110 porn - Page 5 - Defender Source
Old May 19th, 2010, 07:11 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by ECR View Post
So how many folks have actually sat their ass behind the wheel of a truck with LED headlights? (other than JimC as I know he sees them all the time)
I've had a set on a truck for some time now (they were the first 12v pair to go out from Truck light) and have been driving with them for over a year. They seem bright enough but I do notice that I am using the Hella driving lights more, which I would think means they are not quite as good. I dig the low draw and bomb proof aspect. The price will come down..........plus you need multiple direct hits to shoot one out
Matt Browne
Old May 19th, 2010, 09:25 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yes, the question was posed to those where indicating opinions with never having seen the lights in person.
Carey told me you did one set of LEDs on a customers truck, not one of your own.
So how did they do last winter????
The lack of heat seems like a real issue.
What were the results of driving them in the snow and ice??????
Email:
Old May 19th, 2010, 06:18 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
I've done a few customer trucks and one of them lives up here and I drive it a couple of times a week. Didn't notice any real issues with winter, but didn't drive in anything really nasty at all. They get pretty warm so I can't imagine it would be an issue, assuming perhaps ice / snow buildup may be an issue?
Matt Browne
Old May 20th, 2010, 08:53 AM
ECR's Avatar
ECR
Warm? Really??? I just left these ones on for about 45 minutes on high beam and they aren't even lukewarm to the touch? They are pretty much the same temp as the rest of the truck, they haven't really put out any extra heat at all.
Yours get warm?
Updated porn for the masses:
ID:	27774   Click image for larger version
Email:
Old May 20th, 2010, 10:41 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
^^^^^ Nice looking 110 Mike... it's a blue brother of my one! even down to the cage.
Old May 20th, 2010, 10:44 AM
Looks great! Can we get a pic with those lights ON?
Old May 20th, 2010, 11:29 AM
ECR's Avatar
ECR
Here are some shots. Have no idea how to take good pictures with headlights on, but will give it a better try some evening.
These are H4s with upgraded bulbs on the BRG 90 and the LEDs on the Blue 110.
ID:	27780   Click image for larger version
ID:	27782   Click image for larger version
Email:
Old May 20th, 2010, 11:36 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
From looking at the pics the LEDS are brighter than the H4s.
------ Follow up post added May 20th, 2010 11:37 AM ------
Both are awesome!
Old May 20th, 2010, 01:06 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hard to tell much from just looking at them with the lights on, most light comparisons I have seen are typically done pointing out at an object from the same distance at night or in the dark.
I am guessing you are a busy guy so it might not be worth your time but might be useful for your (paying) customers to compare the beam pattern / brightness between stock, upgraded and LED.
Here is a review that I came across when buying a new bike light for my wife as an example of what I am talking about.
http://acidinmylegs.blogspot.com/200...eam-shots.html
That little light uses 3 little LEDís but it is amazingly bright (sadly costs as much as a set of the LED headlights but cars should see her)
Old May 20th, 2010, 01:12 PM
Any thoughts on how they are to drive with (the LED's) i really like the bullet proof ness of them and the ease of the install (i am running an ARB wiring harness + hella E-codes and uprated 100w (?) bulbs) and want a bit better light all in all. i was looking at the 90mm bi-xenon units from hella (would require some surgery to make it work and trim peices, etc - basically a Pita but do-able)
This would be a far simplier solution
95' D90 - daily driver..
Old May 20th, 2010, 01:28 PM
Originally Posted by rlynch356 View Post
... i was looking at the 90mm bi-xenon units from hella (would require some surgery to make it work and trim peices, etc - basically a Pita but do-able)
What about the Sylvania 7" Bi-xenons?
What is really needed is a side by side comparison.... It the the only way to get a good review.
ECR must be able to do that as they have a parking lot full of Defenders????
Old May 20th, 2010, 01:59 PM
those were another option (and a good one really)
Old May 20th, 2010, 02:12 PM
ECR's Avatar
ECR
No trucks here with HIDs.
We'll get to some sort of test someday, but other than for shits and grins there isn't much motivation (as we don't sell any of this stuff).... and this time of year we are f'ing swmped with Nantucket and Marthas Vineyard trucks that have to all be done and delivered prior to Memorial Day weekend.
Email:
Old May 20th, 2010, 02:36 PM
Sorry...too many subjects at once...
A comparison to "stock" headlights and/or a high quality halogen if you have one. Park side by each in front of a wall when it is dark. Compare brightness and beam pattern. 15 minutes of your time....
Old May 20th, 2010, 07:35 PM
KKilo23's Avatar
KKilo23
Kenny
Can't wait to see some of these trucks this summer out there..
Old May 21st, 2010, 07:02 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Yours get warm?
These went from 61deg off to 72deg low beam and 78deg high beam. So you are right, they don't put out shit for heat, and I have no clue as to how ambient temps effect this.
I'd suppose someone with a little more time / search talent could find out more eh?
Matt Browne
Old May 21st, 2010, 07:52 AM
Thanks for those pics, Mike. Gives a better idea of how the blue-ish light looks on the Defender.
Old May 25th, 2010, 04:07 PM
ECR's Avatar
ECR
Td5 porn update
ID:	27959   Click image for larger version
Email:
Old May 25th, 2010, 08:38 PM
surf110's Avatar
surf110
Ze
130 Project
Looks great Mike.
FYI. That Td5 exhaust will melt the powder coat on the ladder bottom tab. HAd to re route mine a little bit to the side.
Td5 porn update
110, td5
Project Zambesi - Td5 NAS 110 surf110 Truck Build-up's & Restores 83 September 18th, 2014 11:45 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
