Starting my 95 RRC refresh - Page 7 - Defender Source
Old September 18th, 2016, 08:26 AM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Will have to check. I don't recall seeing that before but may not have noticed. The truck is at the shop so can't check at the moment.
Old September 19th, 2016, 07:31 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Brent, does your parts truck have a good rear view mirror with the bottom map lights?
(if it hasnt turned dark)
If so, I'm looking for one!
As for your ABS, after so many years I dont think there's any pressure left in the system.
I'd hang on to the pump as they are hard to come by.
Rent my
Old September 28th, 2016, 12:55 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
sorry Nomar - I have already claimed the rear view mirror for my truck.
I did go over and see the truck this morning. I had gotten a call a week ago that the shop owner noticed something in the body work after he had finished the spray and clear coat. There was a spot on the rear quarter that wasn't perfectly strait after body work and paint. So, he sanded it back down to investigate and found a spot where the body man had repaired over an old repair (happened while the shop owner was out of town and not able to inspect). Well that body man is no longer employed there and he stripped the quarter down again, cut out the old repair that was at least 15 years old (had lead based bondo product), welded in new metal and then completed the repair and paint. this is why I am impressed, 1. I would probably not have seen the issue for some time down the road, 2. he took it on himself to correct it without ever bringing it to my attention after it had already been painted, 3. He is not charging me for anything other than what I would have paid for the repair if it had been done during the body rebuild process (he is eating the costs and the paint is very expensive). So, as of this morning the paint and body work is now complete, all green has been painted green and all black has been repainted black. Now it is time to start the rebuild process. I should have it back within the next two weeks! Finally!
Old September 29th, 2016, 06:40 AM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Some pics to show how strait the lines are now.
ID:	158657   Click image for larger version
Old September 29th, 2016, 07:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
darn! If I ever swing through Nashville I want to see this RR when its finished...
Rent my
Old September 29th, 2016, 07:19 AM
roverguy's Avatar
roverguy
Robert
1995 RRC
Can't wait to see this thing! Still need help getting parts off the old truck?
1965 IIa 88
1995 RRC 25th Anniversary
98 Discovery LE7
2000 DII (SOLD)
Old September 29th, 2016, 07:31 AM
signalMTB's Avatar
signalMTB
Rusty
'97 NAS D90 / '94 RRC / '05 L322
Does anyone know if the SWB models had the dog guard brackets built in like a LWB did? My parts car has an original swinging dog guard in mint condition and I would like to install. I don't want to take down my headliner unless brackets are there.
dang it, I knew I should have bought that thing!
I'm actually getting some brackets made for my dog guard...the truck I pulled the guard from, the PO had heat bent them to wrap around the seat release box and jerry-rigged them to screw into it. I'll let you know if these local guys are able to make what I need.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
many others that have sold
Instagram: @SecondDailyClassics
Old September 29th, 2016, 11:21 AM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Sure do. May strip it some more next week. Wednesday and/or Friday.
------ Follow up post added September 29th, 2016 11:21 AM ------
Originally Posted by signalMTB View Post
dang it, I knew I should have bought that thing! I'm actually getting some brackets made for my dog guard...the truck I pulled the guard from, the PO had heat bent them to wrap around the seat release box and jerry-rigged them to screw into it. I'll let you know if these local guys are able to make what I need.
Well, you can still have your parts for free.
Old October 4th, 2016, 07:34 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Took a break from the classic to take the family camping with some friends. Had a blast off-roading in the 110.
ID:	159065   Click image for larger version
ID:	159067   Click image for larger version
Old October 5th, 2016, 11:27 AM
pradaz's Avatar
pradaz
1988 Range Rover
Still need those tailgate lift tabs?
Old October 5th, 2016, 07:22 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Nope. Have two full sets now. Thanks
Old October 5th, 2016, 09:26 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
What do you have?
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 6th, 2016, 07:25 AM
pradaz's Avatar
pradaz
1988 Range Rover
Congleton Service are making upgraded parts for RRC's. Check out their lift tabs: The Finest Land Rover Aftermarket Parts Available Anywhere
BTW, I'm from Nashville and went to Auburn. War Eagle!
Old October 6th, 2016, 08:56 AM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
Those are 3D printed. Do you have a pair? I may buy their wiper cap, but I'm not sure about the finish.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old October 6th, 2016, 04:13 PM
pradaz's Avatar
pradaz
1988 Range Rover
No, I don't have a pair. I was informing Robert that he can purchase them from CS.
Old October 7th, 2016, 07:05 PM
roverguy's Avatar
roverguy
Robert
1995 RRC
Congleton Service are making upgraded parts for RRC's. Check out their lift tabs: The Finest Land Rover Aftermarket Parts Available Anywhere BTW, I'm from Nashville and went to Auburn. War Eagle!
War Eagle! Next time I'm in Atlanta we will have to grab a beer! The finish on the Congleton ones looked off to me as well... I have a set, just seeing if I could find another or better set
1965 IIa 88
98 Discovery LE7
2000 DII (SOLD)
Old October 11th, 2016, 10:17 PM
pradaz's Avatar
pradaz
1988 Range Rover
Sounds like a plan- just PM me. I'll do the same when I go to Nashville. As far as the lift tabs, I don't think that they're meant to be exact replicas. They're supposedly an improved design that won't break as easily. I'm gonna install them for daily use and keep my originals for a concours show (sarcasm). Aren't the originals NLA?
Old October 12th, 2016, 06:14 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I wonder if you could coat or polish the tabs for a better appearance. In the end they are better than nothing.
How are those rivets installed? Just a regular pop rivet gun.
Old October 12th, 2016, 08:25 AM
pl626's Avatar
pl626
Peter
Correct, rivet gun is all you need.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'02 Hobie Getaway
Old October 15th, 2016, 05:55 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Major progress in reassembly today. Got all carpets, rear seats, all four doors put back together and center console installed.
ID:	159855   Click image for larger version
'87 110 Refresh, Restore, Rebuild and Update TheOneTen Truck Build-up's & Restores 240 April 6th, 2018 10:31 PM
Defender 200Tdi refresh BostonAndy Smaller Projects 5 June 10th, 2015 05:25 PM
Transceiver Refresh Bill Larson Misc. Chit-Chat 13 April 29th, 2015 06:51 AM
Rear Axle: 10 Spline to 24 Spline Conversion / Seal Refresh / Ashcroft Locker Install sonoronos Smaller Projects 44 February 27th, 2015 04:20 PM
Refresh me on the issues with 35's btate Defender Technical Discussions 15 September 12th, 2006 06:35 AM
