Spacers for Boosts on ROW 110? - Defender Source
Old February 13th, 2013, 04:22 PM
atpick's Avatar
atpick
Andy
1990 110
Finally a good junkyard find! Question, will I need spacers to put these on my 110? I have some lying around I was just curious if I will need them.
Old February 15th, 2013, 05:53 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Depends on if your 110 has drum rear brakes. If so, then yes (although you /can/ make them fit, with a die grinder and the rubber hub cap poking out the centre of the wheel.... rough method of fitting though)
Old February 17th, 2013, 11:42 AM
atpick's Avatar
atpick
Andy
1990 110
Ok, I have front discs but rear drums. Sounds like I will need to use my spacers, thanks for the info.
Old February 17th, 2013, 12:53 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
If you'rs is a "factory" spec drum/disc setup (with the larger centre rubber cap and 23 spline CV's) then the alloys won't fit on the front properly either.
Spacers is the easy way to go.
110, ac, boost
Defender nas 110 middle row seats 60/40 bench jonathon For Sale - Parts 0 February 29th, 2012 07:46 PM
ROW 110 Front Driveshaft Length Fuzzy Math Wolf Fabrication Defender Technical Discussions 10 April 5th, 2010 06:14 PM
1987 row 110 Bozman For Sale - Vehicles 16 February 21st, 2010 08:27 AM
Why is my floor so wet - 110 second row bjf Defender Technical Discussions 6 January 20th, 2010 12:48 PM
ROW 110 Ex Saudi LHD Brenter Truck Build-up's & Restores 11 December 31st, 2009 01:29 AM
