Series 88 on 40s - Defender Source
Old December 13th, 2007, 10:54 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
Series 88 on 40s
Dana 60
14 bolt rear
39 in crawlers
375 hp 350
4 speed
atlas t case
Name:	post 88 2.jpg
ID:	11365   Click image for larger version
Name:	post 88 3.jpg
Name:	post 88 4.jpg
ID:	11367   Click image for larger version
Old December 13th, 2007, 01:07 PM
WOW- that was the tub that was for sale @ MAR ? You have come a long way since October.
Are the pen lines on the fenders where you are going to cut ?
Interesting frame design- and outrageous horsepower. Should be wild.
Old December 13th, 2007, 01:17 PM
ridonkulous.
make sure you install a rollbar dude.
Originally Posted by mvancuren
Dana 60
14 bolt rear
39 in crawlers
375 hp 350
4 speed
atlas t case
Old December 14th, 2007, 07:19 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
cage
I will a big one
Old December 14th, 2007, 09:13 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Cool project!
My .02 is that if you can, stretch the wheelbase several inches. I've been running 37" krawlers on my 90 for years and it is rare that I find myself in a situation where I don't have the ground clearance I need even at 3psi. Bigger tires and a short wheelbase, especially on climbs or ledges, will get sketchy quick.
I'm assuming since you are running an atlas this isn't a mud truck where you might need taller tires.
Tis
Old December 14th, 2007, 09:49 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm not sure, but in the pictures it looks like he did stretch it several inches. Out of curiosity, why did you stay with the leaf springs...just simplicity?
Looks great though, keep us up to date!
Old December 16th, 2007, 09:11 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
its stretched to 100
i did the leaf springs for simplicity
i want to wheel not fix things
i will coil it in a few years
Old December 16th, 2007, 05:22 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
100 is probably perfect.
Trust me, you will still fix broken things...hopefully just less often.
Old February 19th, 2008, 03:54 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Any Updates? Love the project.
EwS
Old February 27th, 2008, 08:34 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
you can follow it on dwed
88 on 40s
Old February 27th, 2008, 11:49 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
pics
some flex pics
ID:	12362   Click image for larger version
Old March 10th, 2008, 01:13 PM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
new pics
just some new pics
ID:	12544   Click image for larger version
ID:	12546   Click image for larger version
ID:	12548   Click image for larger version
ID:	12550   Click image for larger version
Old March 12th, 2008, 12:00 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
wow!!
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old March 12th, 2008, 12:50 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Hey man, I really like the rear cut. Can you send me some side profile pics and some other rear frame shots with the tub off if you have them. I'm trying to stretch my 90 in a similar way without dovetailing or totally chopping the fenders. I can't view anything on the other site without signing up. Cool build!
Tis
Old March 12th, 2008, 04:13 PM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
Pics
I Will Take Some This Week
Old March 13th, 2008, 03:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
40" is a lot of tire for 100in IMO. Great build though, really dig it.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 13th, 2008, 07:10 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Well a 40" aired down to 3-5psi is probably more like a 36-37", which is where I run my air pressure. Agreed 40" at trail pressure is a bit much for that wheelbase.
Old March 13th, 2008, 11:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I get what your thinking, but it doesn't really work like that. Your red labels do probably give you more give at 5 psi than mine do, but it's the center of gravity, which is higher by fitting those tires. Also, when you start going over, the crush of the tire rotates out from underneath the truck, if that makes any sense. On a 93in wheelbase, 37's are really 34's but it doesn't mean you should run more tire. The last reason, but a big one, is climbing. Nothing matters as much as wheelbase on a waterfall.
I would want 105 min. But thats an opinion and, with leafs he won't have unloading issues. I love the build, I don't want to hijack it too badly.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 14th, 2008, 08:32 AM
mvancuren's Avatar
mvancuren
mike vancuren
1995 Disc
Well We Ended Up At 103in Wheelbase
I Hope It Will Work
Old March 14th, 2008, 08:50 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
I agree it depends on the type of terrain, see my first post about ledges and falls as you point out. I still disagree with regard to the impact of the COG on many techincal boulder strewn trails where ground clearance is more important that COG. Sidewall deflection/deformation may come into effect but keep in mind in at least my case and I think in mvancuren's that we run 17" rims which reduce that some. No doubt an IROK sidewall is stiffer than a BFG Krawler. Bottom line is IMO the nearly 15" he gained in wheelbase and the extra width it looks like he has will be a good combo with that tire size.
Tis
series
1969 Land Rover Series IIa 88 colton For Sale - Vehicles 18 August 3rd, 2009 05:33 PM
300 TDI in a Series 88 coiler 49COE Truck Build-up's & Restores 5 January 13th, 2009 10:16 PM
1974 III Series 88 SW Prototype For Sale Nil For Sale - Vehicles 0 August 10th, 2005 02:39 PM
Series 88 roof top and sides kellymoe For Sale - Parts 0 January 27th, 2004 01:12 AM
