Series 109 2a 5 Door - Page 7 - Defender Source
Join the Defender Source Community Today
Old September 25th, 2016, 07:30 AM
bossman429's Avatar
bossman429
Adrian
1988 90
defenders are in the rear. Designa was going to weld on the plate for the p38 box ?
Supposed to. Circled the option on my form and paid 80 pound for it
Not the end of the world, I can fab up. But I'm gonna have to guess a little on exact location
Old October 10th, 2016, 01:03 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Spoke with Ian. Mis understanding on my part. It was set up for a 90 box. I'll be retrofitting the p38 box looks like
Will leave more room for plumbing and a stronger box anyways. Just need to mod a few things to make work. Doesn't look too difficult
Old January 15th, 2017, 03:13 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Well its been way to long since I've made any progress on this... but finally got some items on the list crossed off
I installed my power steering box and lower link off a RRC, which went it very easily.
The steering tub required some fabrication, mainly a lower bracket to hold a bearing, lengthening the steering shaft with a weld on piece (3/4-48 spline end). I felt like everything on this wanted to fight me for stupid reasons, but in the end I'm happy with the result. Also made a gasket for the steering column out of some soft 3/16" rubber.
I had the last bits of my suspension line-xed once i knew they would work. Put in new poly-bushes as well and got those put in.
Next up is getting the power steering pump mounted into the engine and lines ran to the box. Then i think i have to tackle the rear tub/battery box etc so i can start wiring. That should only take me into 2018 at this rate.
ID:	193497   Click image for larger version
ID:	193513   Click image for larger version
Old January 15th, 2017, 03:14 PM
bossman429's Avatar
bossman429
Adrian
1988 90
more pics...
edit - all rotaed 90 degress off and i dont have the patience to flip em right now lol
ID:	193537   Click image for larger version
ID:	193553   Click image for larger version
Old January 15th, 2017, 03:30 PM
Nice, although I"m personally not a fan of the rough surface on those suspension parts - will trap dirt.
Can you share the part # on the bearing you used? I went and did something very stupid on mine and used a linear bearing and didn't realize it until it was all done (and bracket galvied!)
Originally Posted by pendy
I'm here for the D's
Old January 15th, 2017, 09:34 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Originally Posted by cgalpin View Post
Nice, although I"m personally not a fan of the rough surface on those suspension parts - will trap dirt. Can you share the part # on the bearing you used? I went and did something very stupid on mine and used a linear bearing and didn't realize it until it was all done (and bracket galvied!)
McMaster Carr 6494K42
It's not perfect though. The body of the bearing carrier is larger than the bolt pattern of the column flange, so you have to have just the right size bolts to connect the flange without pushing out on the bearing on the other side. Also the material needs to be thick enough to tap so you don't need a nut on the other side of the flange. (I used 5/16 steel plate)I couldn't find any bearing
As for the line x. I had them use the premium finish which is shiny and almost like a pvc coating. While it's still textured it's not nearly as gritty as some cheaper rattle can bed liners. I think dirt will easily come off with not much more than a hose. My main concern was durability and ability to keep things from rusting. I don't think there is s better product out there. Paint, powder coat or otherwise.
109, door, series, series 109
Land Rover series lll 109 British fire unit :: 1983 Land Rover Series ll 109 5 door idartist45 Defender & Series Truck Registry 0 June 23rd, 2014 11:45 AM
