Series 109 2a 5 Door - Page 3 - Defender Source
Old August 18th, 2015, 04:27 PM
RRC front calipers are split into two circuits.
Originally Posted by bossman429 View Post
explain por favor
i take it the range rover had a dedicate line from the MC to each caliper, while the series had one line that split with a "tee" left to right?
Going to be putting in all new brake lines anyways so that's easy enough and no extra work.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 18th, 2015, 04:39 PM
bossman429's Avatar
bossman429
Adrian
1988 90
got it assume one inside one outside
Old August 18th, 2015, 04:56 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Do a search for a RRC brake circuit diagram.
-Jeff
yea - that seems like a silly design with more parts to fail than necessary.
I think I'll just get calipers for a d1 and use those.
Old August 22nd, 2015, 08:37 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Finally done with tearing the truck down. Have all the parts in the garage ready for media blasting. Obviously the Rear tub and top are not pictured, as those are in the backyard and pretty much will be there for another year or 2 before i need to bother with them.
Going to get everything media blasted and then see what needs to be repairs, whats good to go.
Finally - i think i get to start building now.
First phone call Monday will be to Designa chassis to get my chassis ordered.
Also going to order some stuff from YRM to get me going.
Old August 22nd, 2015, 09:12 PM
I urge you to try dipping over blasting. Way less traumatic to the parts and it gets inside as well as outside.
Old August 22nd, 2015, 09:43 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I will look into. Any particular process of solution I should look for. Only dipping I know is what they do prior to galvanizing.....but that doesn't take off paint or rust really.
Old August 22nd, 2015, 09:56 PM
Look for a shop that does chemical stripping. You get your stuff back cleaned down to white metal. Cost is more than blasting but its far more thorough and you are assured all the rust is killed. Afterward you galvanized the steel parts.
Old August 27th, 2015, 08:40 PM
bossman429's Avatar
bossman429
Adrian
1988 90
The pile of parts i had in the garage is gone and at the media blaster. i wasn't able to find anyone locally who could dip the parts to strip them. I told them to be extra careful with the Aluminum, we'll see what happens.
That made some room in my garage to tackle the axle assemblies i picked up out of a D1.
Tore the rear apart, and it seems to be in very good shape. Grease in the bearings was a little dirty but the races seems to be fine and the shafts and everything look to be in great shape. The truck they came out of was never wheeled thats for sure.
Im thinking about having the axle tubes Line-xed. I figured its the most durable coating out there and this is probably the most vulnerable part of the truck in terms of road debris/gravel, salt etc. again - the idea behind this build is to have everything last as long as possible.
Stub axles and hubs all look to be good. Obviously new calipers and rotors are going on, and I'll paint everything in a clear high heat paint so they don't rust (aside from where the pad contacts them)
ABS sensors and rings are getting taken out, don't plan on putting that back in.
Rear sway bar is off but I'll leave the bracket on the tubes incase i want to add later.
ID:	128194   Click image for larger version
Old August 27th, 2015, 10:39 PM
Hope your panels come back straight and not all warped from blasting!!!
Honestly, use the cheapest rustoleum enamel on your undercarriage. You won't feel bad about it getting scraped and you can touch it up with a rag soaked in paint.
Old August 28th, 2015, 01:59 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Hope your panels come back straight and not all warped from blasting!!! Honestly, use the cheapest rustoleum enamel on your undercarriage. You won't feel bad about it getting scraped and you can touch it up with a rag soaked in paint.
I'm really on the fence about the chassis paint. Part of me says to do what you mention. But the other half is like I'm going to be really pissed if in 2 years spots of rust are popping up. Whole point of this build is to make it as rust proof as possible.
As for the panels. Yea it's a gamble I guess. I couldn't stress any more to the blasters how careful they need to be with them.
Old August 28th, 2015, 10:22 AM
Jopadorr
John Dorr
59 109 hybrid
old frame
Bossman, I could use your old frame. Please dont junk it. will come collect it...John in Delhi, NY
Old August 28th, 2015, 10:23 AM
bossman429's Avatar
bossman429
Adrian
1988 90
I'm sorry. It's already gone
Old August 28th, 2015, 02:50 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Thought you were getting a galv chassis? Why not just get the axles glav'ed as well? You will be driving it so much; salted roads, winter, off road, etc... Just be easier to rattle can it like o2batsea says.
Old August 28th, 2015, 03:48 PM
bossman429's Avatar
bossman429
Adrian
1988 90
I am getting a half chassis. I'm going to assume that was sarcasm about galvy axle tubes
Point is would I rather "touch it up" every year or spend more money now and not touch it for 25yrs+
Old August 28th, 2015, 03:51 PM
airbornrover
William Skidmore
SIII 109 SW
Put the chassis together and get it galv'ed then. Galv'ing axles has been done. Theres pics on here before and after. Its a real thing I swear.
Old August 28th, 2015, 04:04 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Maybe I should put the engine in too lol
Old August 28th, 2015, 06:49 PM
Where? I was going to do this and chickened out. Couldn't find any pics or success stories.
Originally Posted by pendy
I'm here for the D's
Old August 28th, 2015, 07:28 PM
bossman429's Avatar
bossman429
Adrian
1988 90
If he's serious that's a horrible idea. Every bolt will snap if you ever have to take it out
Old August 28th, 2015, 08:45 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
If you want "as rustproof as possible " then the answer for all steel parts is hot dip galv. Axle housings too -why not?
Old August 28th, 2015, 09:06 PM
Do you mean the ring bolts for the diff? Those are studs and it would be easy to just replace them after galvy if it was a concern.
109, door, series, series 109
Land Rover series lll 109 British fire unit :: 1983 Land Rover Series ll 109 5 door idartist45 Defender & Series Truck Registry 0 June 23rd, 2014 11:45 AM
