Santana 200tdi hybrid build - Page 2 - Defender Source
Old December 7th, 2014, 01:41 AM
santana109
david
1983 santana 109
Sorry transient mechanic I cant find a good photo of the motor prior to tear down
Old January 5th, 2015, 03:00 PM
santana109
david
1983 santana 109
Problem of living in Alaska is its to damn cold to power wash outside. so I had to move into the garage and hook up to the water from the back of the washer. One side is painted and letting the other side dry then paint
Old January 7th, 2015, 03:54 AM
aka rover's Avatar
aka rover
ed angel
95 D90
David looking good buddy !
Keep up the momentum.
June is coming soon !
85 D110 3.5 3 DR
Old January 14th, 2015, 09:47 PM
santana109
david
1983 santana 109
Well 7 months still no frame at least the motor is looking good lol
Old January 30th, 2015, 10:53 PM
santana109
david
1983 santana 109
It's finally here. LETS DO THIS
Old January 31st, 2015, 03:14 PM
Alaskantinbender's Avatar
Alaskantinbender
jim
63 series 2A 109 3 door
Very nice, looking forward to the build.
1995 D90 SW 338/500
1963 S2A 109 3 door
Old January 31st, 2015, 05:35 PM
santana109
david
1983 santana 109
Entire wiring harness from auto sparks including towing harness $400 and only took 4 days to get here. This will make the install much easier
Old February 11th, 2015, 11:11 PM
santana109
david
1983 santana 109
Cleaned disco axles and primed frame with galvy primer. Also managed to trip and hit my back on the corner of the bumper. Wow did that hurt
Old February 27th, 2015, 08:10 PM
santana109
david
1983 santana 109
I got some more work done on the rover this week. Made rear upper control arm brackets, I do not understand why these are not welded to the new frames. Surprisingly found out you can fit 4 35s tires, 5 15x10s wheels and a car seat in a Jetta with some persuading. I also went and bought a bunch of pvc to make a much larger paint booth to finish more panels at once.
Old March 5th, 2015, 04:50 PM
santana109
david
1983 santana 109
Test fit the engine and turns out the turbo side engine mount bracket is wrong so I either need to make one or purchase one.
Old April 3rd, 2015, 01:27 PM
santana109
david
1983 santana 109
Progress has been slow next week will be in high gear, 9 days off to devote to the rover.
mounted some panels to check fit and see what needs to be trimmed for tires.
Brakes are 80% done just need frame to bulkhead connection and front caliper brackets.
Had to buy a new brake flare tool old one was crap
fuel lines are done used -80/+300 poly lines wrapped in plastic housing and new tank
tore into transmission to install new mainshaft and replace baulk rings
my little helper not being so helpful
I finally spent the money and bought an impact driver and new drill best money I have spent in a long time on tools,
Old April 3rd, 2015, 04:18 PM
Alaskantinbender
jim
Its coming along nicely. Keep up the good work.
That's going to be a terrific truck when your finished.
1995 D90 SW 338/500
1963 S2A 109 3 door
Old April 4th, 2015, 01:56 PM
aka rover's Avatar
aka rover
ed angel
95 D90
looks like you need bench space to build that LT85 soon .
85 D110 3.5 3 DR
Old April 7th, 2015, 08:09 PM
santana109
david
1983 santana 109
I wish I had room for a bench stupid washer and dryer
Updates couldn't find a brass bushing or bearing to work for the steering shaft, so Home Depot to the rescue. I made a make shift lathe with my drill and a fill ,worked out awesome.
Old April 7th, 2015, 08:17 PM
U haz skillz.
Great work - enjoying following your build. The talent on this forum is pretty amazing.
Old June 14th, 2015, 07:03 AM
Gas_Donkey's Avatar
Gas_Donkey
Julian
D110 Series 3 & Santana 2500
Great build. Are you using the orignial Santana front Fenders or are you going Defender or series 3 fenders as i have done on a few cars now?
Gas Donkey Land Rovers Spain
Exporter of 100% original Land Rovers
Search Gas Donkey Land Rover on Facebook
Old June 16th, 2015, 09:14 AM
santana109
david
1983 santana 109
I used new series headlight frames. lets just say I have a lot of catching up to do on adding pictures and updates. Still lots of little things left and paint
Old June 16th, 2015, 01:30 PM
Gas_Donkey's Avatar
Gas_Donkey
Julian
Interesting, did you just bond them on? as the originals are aluminium welded.
Old July 29th, 2015, 12:25 PM
santana109
david
1983 santana 109
More painting accomplished
Donkey I used lots of rivets to bond the series headlight housings to the santana fenders
Old October 9th, 2015, 10:02 AM
santana109
david
1983 santana 109
So winter is getting very close and the problem I have now is it dosent fit in the garage without airing down, bummer
200tdi, tdi
Hybrid build question Jake1996d1 Defender Technical Discussions 23 May 23rd, 2012 02:26 PM
WTB D90 body parts - Considering a hybrid build. Roving Beetle Wanted 15 February 26th, 2010 12:19 PM
D90 on TMZ.com (backgrond of Carlos Santana) kennybahr Misc. Chit-Chat 0 October 6th, 2008 11:47 AM
LR->Santana->Iveco Monkeyboy Misc. Chit-Chat 1 November 18th, 2007 06:54 PM
Santana PS10 the better Defender? D110XD Misc. Chit-Chat 3 June 7th, 2005 09:48 AM
