Sam's Defender 90 restoration - Defender Source
Old December 3rd, 2013, 12:08 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
So as some of you already know I pounced on this truck that popped up on craigs list locally a few weeks ago. Its a 95 ST. The previous owner off roaded it pretty hard but it only has 68k miles. He was able to achieve a salvaged CA title status due to the fact that he rolled it over on some sand dune. He told me his insurance co compared the cost of replacing all the body panels with the blue book value and decided to just pay out the total value. He kept the truck and essentially did nothing to fix it after that other than beating out a few of the body panels.
Due to the fact that I like doing restoration work and it needs so many body panels anyway I've already started stripping it down to the frame for a complete restoration. This is a west coast truck so I'm not running into any major rust issues which is refreshing after my last build. The frame is in perfect condition with only minor surface rust in a few spots so I'm gonna send it to a place in AZ to be sandblasted and hot dip galvanized. I've got new body panels on their way from Safari HP. I'm gonna try to keep it fairly stock except for a few little upgrades I think will be cool. I'll just keep you in suspense for now. (Here's a hint: I'm not fond of manual transmissions)
I've never been a fan of white and although I'm nowhere close to paint yet, I'm leaning heavily toward a bonatti grey type color. I really like G4 orange too but thought it might be to obnoxious.
ID:	85223   Click image for larger version
ID:	85225   Click image for larger version
ID:	85227   Click image for larger version
ID:	85229   Click image for larger version
ID:	85231   Click image for larger version
Old December 3rd, 2013, 12:11 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Sam's 90
Here's where i'm at as of today.
ID:	85233   Click image for larger version
Old December 3rd, 2013, 06:59 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Sub'd
You move fast! For a salvage NAS I think a color change would actually increase value. Although, done correctly and with a good color - which sounds like you have covered.
Old December 3rd, 2013, 08:14 AM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
Nice work, Sir! And, great find! Keep the updates coming!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old December 3rd, 2013, 11:28 PM
We missed that one - Enjoy
95' D90 - daily driver..
Old December 5th, 2013, 07:47 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Started on the engine today. Previous owner put in a 4.2 ltr block. Internals look good so far. I'll have the heads hot tanked, shot peened, new valve stems seals and new valve springs. This engine will get new head gaskets, new head bolts, new valve cover gaskets, new rear main seal, new timing chain cover seal, and reseal the oil pan.
I'm also gonna switch all the ancillaries over to a serpentine belt set up from a 95 Disco. I hate the other set up. Ever try to change the power steering pump on that set up? No thanks
Old December 5th, 2013, 09:46 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Keep those pictures coming! I'm about to replace my rear wing skins, so it will be great to know what to expect. Sub'd!
Old December 7th, 2013, 10:28 PM
chuckc4
chuck b
Registered User
Are you going to dip the bulkhead too?
Old December 8th, 2013, 01:07 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Goodbye frame! Off to get sand blasted and hot dip galvanized. Next time I see it, it'll be shiny zinc.
Not doing the bulkhead. It's going to get painted then coated in and out with line-x.
Old December 8th, 2013, 08:35 AM
Crap I was just in Vegas too. Cold as F.
Old December 8th, 2013, 09:53 AM
Ahh!! After having done this before: galvanize everything steel if you can! Bulkhead included!
Looks great though
Old December 12th, 2013, 04:49 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Since my frame is out getting galvanized and the engine is at the machine shop I decided to do some work on the rear axle. Cleaned it all up and repainted it. I used high heat spray paint on the calipers. Brand-new rotors and brake pads.
ID:	85973   Click image for larger version
ID:	85975   Click image for larger version
Old December 12th, 2013, 05:25 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Why line-x all over the bulkhead?
lookin' good by the way...
Old December 12th, 2013, 05:52 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Whoa! That looks great. I am in the process of installing my Toy axle on my galvy frame and I am going to paint the calipers, hub, and rotor hat. This will give me some motivation.
I would take off those dust plates tho. They seem to do more harm than good (as in holding moisture and dirt in).
Old December 12th, 2013, 05:56 PM
Ironically I always thought that too...BUT we found recently that they can be fairly effective oil/blowback barriers. I recently had a trans issue that literally blew MTL all over the place - only thing that saved me from replacing my brakes/rotors (in theory) was that the dust shield totally kept all the fluids off the brake setup.
Huff or Galpin had a similar experience recently with a leak as well if I recall...so we've been converted to looking at them not as dust shields, but as leak shields!
Old December 12th, 2013, 11:55 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Originally Posted by revtor View Post
Why line-x all over the bulkhead? lookin' good by the way...
I talked to Stephen at Safari HP. He told me that's what they do. I've seen it on some of his builds and it looks cool. Seems it would deaden sound and insulate against heat a little too.
Old December 13th, 2013, 12:07 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Like this
Name:	linex bulkhead.jpg
Old December 13th, 2013, 12:17 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Like this
i did the same thing but I laid down dynamat before the spray liner
Old December 13th, 2013, 10:15 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
haha, leak shields. Never thought of it that way. That must have been a hell of a mess with the tranny to get fluid that far out to the axles! No need for waxoyl tho :D
The ones with this axle were so rusty I just tossed them. The ones that were on the 90 went back with the new owner.
Old December 20th, 2013, 09:24 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Finally got my frame back from being galvanized so now I can start making some progress!
ID:	86473   Click image for larger version
90, defender, defender 90, restoration
F/S 1995 Defender 90 ToddR For Sale - Vehicles 9 September 19th, 2016 06:09 PM
1995 NAS Defender 90 For Sale sgttom For Sale - Vehicles 2 May 27th, 2009 04:37 PM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
UK defender 90 110 130 brochure mpodgorski For Sale - Parts 1 June 25th, 2004 02:13 PM
