Sam's Defender 90 restoration - Page 2 - Defender Source
Old December 20th, 2013, 09:58 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Sexy
Old December 20th, 2013, 10:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Wow, that's some good galvy---looks like chrome platin'!
Rent my
Old December 21st, 2013, 12:56 AM
cwilder's Avatar
cwilder
Chad
2012 110 Black
Where in Vegas are you located? Looks great so far. I have a 97 but haven't shipped it to LV yet. Its in Orlando and I'm considering sending it to Safari HP for some work before shipping this way. I'm up in Summerlin and have spotted a Yellow D90 and thats it as far as rovers around here.
_________________________________
2016 Range Rover TD6
2013 Raptor F150 SVT
1997 D-90 #1867 (sold) :(
2012 Black 110 :) In OZ still
2011 LR4 "Metropolis" (sold) :(
2011 Raptor F150 SVT (sold) :(
2007 Shelby GT500 (sold)
2007 LR3 (sold)
2006 RRS (sold)
Old December 21st, 2013, 07:57 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I live in Silverado Ranch area. Yes, Defenders are definitely a rare site around here compared with the east coast.
Old December 21st, 2013, 08:11 PM
FYI, even in the seeming hotbed of defenders (NC) outside of Nantucket, I'm lucky to spot one a month, if that.. Usually less than one every few months.
95' D90 - daily driver..
Old December 25th, 2013, 09:27 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I had my brother install a new rear ball joint for me and started getting the front axle and brakes together.
ID:	86675   Click image for larger version
Old January 6th, 2014, 12:13 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I've got it to the point of being a rolling chassis. Since I have the engine out I decided to bite the bullet and just redo everything so I can be sure it's all good. It's a 4.2 ltr with the following done:
Block hot tanked, all new main and rod bearings, the main was align bored, cylinders honed, new piston rings and seals, crank shaft hot tanked and polished, all new freeze plugs, new crower cam 50229 and hydraulic lifters, new crank gear, cam sprocket and timing chain. New rear main seal, front crank seal and timing cover gasket. New water pump and gasket.
The heads have been hot tanked, decked and bead blasted. New valve stems, springs and seals. New head gaskets, head bolts, intake manifold gasket and valve cover gaskets.
A lot of this was done at a machine shop my brother recommend. He's used it a lot through the dealership. Him and I did the head gaskets. It's easy to get right when you have a LR master tech watching over your shoulder.
More pics to come as I get more of it together!
ID:	87390   Click image for larger version
ID:	87392   Click image for larger version
Old January 8th, 2014, 12:03 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
Awesome!
Old January 17th, 2014, 08:14 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I got the front half painted in Arles blue. Wheel spaces and tires installed. Bulkhead, gas tank and fuel lines in. The foot wells and floor boards are being covered in a stick on heat/sound insulating matting (boom mat) the 2 coats of truck bed liner. Should help keep down on the noise and heat a little while being durable. I researched this idea on a few Jeep forums. Seems like a good combo. We'll see. I also got a coat of bed liner on the seat box. I'm using Monstaliner. So far I like it.
ID:	88032   Click image for larger version
ID:	88034   Click image for larger version
ID:	88036   Click image for larger version
ID:	88038   Click image for larger version
Old January 17th, 2014, 08:23 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
That's a piece of living art! Looks very good!
Old January 17th, 2014, 08:28 PM
The paint looks a little dark, is that just the lighting in the pictures?
Old January 17th, 2014, 08:58 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
My garage is dark. It looks right out in the sun
Old January 17th, 2014, 09:04 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
I don't think anybody is going to care a thing about that "salvage" title when you're done! She's looking great, sir!
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old January 17th, 2014, 09:05 PM
Grover's Avatar
Grover
Did you paint in the garage?
Old January 17th, 2014, 10:33 PM
This is a great looking rebuild so far, good work!
Old February 2nd, 2014, 02:10 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I cleaned up the galvanized inner fenders but they still didn't look pretty so I primed and sprayed them in Zambezi silver. Installed the wings and headlights then got the heater, washer bottle and brake booster connected and installed the radiator too. Just started putting the dash together. I want the front half done before I finish the back end.
ID:	89058   Click image for larger version
ID:	89060   Click image for larger version
ID:	89062   Click image for larger version
Old February 2nd, 2014, 03:01 AM
Look so weird with just the inner fenders on.
Old February 2nd, 2014, 10:16 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Is it lifted?
Old February 2nd, 2014, 10:25 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Looks like you have a '95 serp 4.2
Is there any internal difference in the 4.2 v-belts of 93,94 and the serp 95?
Great looking buildup.
Rent my
Old February 2nd, 2014, 11:03 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
It's got about a 1.5 to 2 inch lift. The 4.2 is from a LWB RR classic and the serpentine belt setup is off a 95 disco. Switching to the serpentine belt setup is fairly involved. Besides the timing cover and ancillaries you gave to change out the intake manifold, oil cooler lines, heater hoses, fan shroud. Not too bad if you have a donor vehicle. In the end I like how it modernizes it a bit.
90, defender, defender 90, restoration
F/S 1995 Defender 90 ToddR For Sale - Vehicles 9 September 19th, 2016 06:09 PM
1995 NAS Defender 90 For Sale sgttom For Sale - Vehicles 2 May 27th, 2009 04:37 PM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
UK defender 90 110 130 brochure mpodgorski For Sale - Parts 1 June 25th, 2004 02:13 PM
