Sam's 110 resurrection - Page 5 - Defender Source
Old December 22nd, 2011, 10:38 AM
spartan's Avatar
spartan
Fred
83 D110
Sam,
Amazing build. I will do one some day.
I need to source the side window felt for my D90. where did you get your felt?
Old December 22nd, 2011, 12:18 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Home depot. It was cheap, easy to install and works great.
Old December 24th, 2011, 12:21 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I made a new dash instrument dash cowl piece out of steel to replace the wimpy plastic one. I know someone makes one out of aluminum but I like fabricating my own stuff. I started into the dash wiring. I first peeled the lower dash pieces, had them sand blasted, primed them, then used a faux leather material, spray glue and a heat gun and recovered them. Came out better that I imagined it would. I bought the TD5 upper dash piece to replace the vent cover and dash tray. Took some very minor modification but it looks good in place. I'll take pics when I get it installed.
Name:	2011-12-10 14.13.53.jpg
ID:	45251   Click image for larger version
Name:	2011-12-11 14.37.00.jpg
Name:	2011-12-23 15.52.13.jpg
Old December 25th, 2011, 01:25 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Got a little more of the dash and column put together then put the steering wheel on. Not done with the wiring yet but I put the TD5 upper dash panel in to get an idea of how it's gonna look. Still need to buy a radio and a grab handle.
Name:	2011-12-24 21.58.05.jpg
ID:	45262   Click image for larger version
Name:	2011-12-24 16.09.49.jpg
Name:	2011-12-24 21.57.49.jpg
Old December 25th, 2011, 08:37 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Looking nice!
Old December 25th, 2011, 01:02 PM
Grover's Avatar
Grover
Geat build. What motor?
Old December 25th, 2011, 05:08 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
4.2 from a 93 RRC LWB
Old January 8th, 2012, 12:39 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
So I drove 10 hours each way this weekend to the back woods of California to pick up 4 110 station wagon doors and a newer style 110 roof with no external ribs. Very happy with the doors. They are from a 96 Australian 110. Just about perfect. All I have to do is paint them.
Air springs on the Disco started giving out on this trip. Time for a coil conversion asap.
Name:	2012-01-06 17.00.22.jpg
ID:	45807   Click image for larger version
Name:	2012-01-07 10.34.54.jpg
Old January 8th, 2012, 11:41 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Excellent! Congrats! What did you think of the 88" rig in his garage? Pretty cool huh?
Daniel
Old January 9th, 2012, 10:24 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
What's really cool is the 1948 Land Rover he's got. Its the 2000th Rover made I think he said.
Old January 21st, 2012, 02:42 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
A few weeks after assembling the engine I noticed the power steering pump leaking so I decided to change it out. I don't like the pump set up that comes on the 14cux v-belt classic 3.9 and 4.2 so I made some upgrades. This is the third pump I've bought and installed from PSC Motorsports into one of my rovers. Makes it steer like butter! Its a high out put TC style pump. Puts out much better pressure than stock and in my opinion much more reliable and less likely to leak. I used this pump in a set up with a hydraulic steering ram once and it kept up with that. It required modifying the stock bracket it mounts to (you better have a welder if you're gonna do this), having a custom hose made, buying a 4.5" diameter pulley and 90 degree hose barb PSC sells, and buying some fasteners and a smaller belt. In the end it was definitely more work than just putting in the stock unit but I ended up with something superior and spent about $290 instead of $340 for a new pump from Atlantic British. The one pic shows a straight hose barb fitting for the return line. I ended up switching it to a 90 degree after a test fit. I hate just putting the same old poorly designed whatever back in when I fix something. I usually try to go one better if possible.
Name:	2012-01-19 16.12.55.jpg
ID:	46422   Click image for larger version
Name:	2012-01-19 16.13.13.jpg
Name:	2012-01-20 22.17.04.jpg
ID:	46424   Click image for larger version
Name:	2012-01-20 22.18.23.jpg
Old January 21st, 2012, 02:56 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I also found a company that makes aftermarket a/c units for classic cars and trucks. I have all the under hood parts I needed but didn't know what to do about an under dash evaporator. I could buy a used one from some one for $500-$800 then hope it works and that the vents don't fall out. Instead I bought a brand new unit made for putting a/c in a 67-72 Chevy pick up. I took a little bit of a gamble but I'm happy with how I got it to fit. Of course I did have to have new custom high and low pressure a/c line made but i like brand new stuff. I'll keep you all posted on how it actually performs. I should have the truck up and running in about 2 months if all goes well. Then it'll be 110 degrees out by mid August. Should be a good test.
Name:	2012-01-13 09.33.51.jpg
ID:	46426   Click image for larger version
Name:	2012-01-20 22.55.59.jpg
Old January 21st, 2012, 06:52 AM
Good on ya for figuring out something different for an AC solution. This looks a little more in keeping with the character of the older trucks, since retrofit items looked more fabricated and assembled instead of looking perfectly integrated. I mean that as a compliment, really.
Can wait to hear how it performs.
Old January 21st, 2012, 12:06 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
a/c
The great part is that this under dash a/c unit was $300 including shipping. I'm willing to be the guinea pig on this.
Old January 21st, 2012, 12:17 PM
It looks like a good match! Please share all the details once you verify it works well.
Originally Posted by pendy
I'm here for the D's
Old January 21st, 2012, 02:31 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I know. Installing the stock one was an impossibly difficult task. Installation of this new pump is a lot easier.
Old February 3rd, 2012, 06:44 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Started the engine for the first time since it's been refurbished. It runs great! I'm so excited. I can see myself driving already. Much thanks to my brother Scott. I would've been lost without his expert help. It really spoils you when you have a Land Rover master tech on speed dial.
Old February 4th, 2012, 07:50 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Great Thread.. Nice Job
Legend in My Own Mind.
Old February 10th, 2012, 08:07 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Since the truck runs now I drove it up and down my street a bit. I also installed a fold and tumble back seat from a Jeep TJ. I custom made seat brackets. It works great. You can even pop the whole thing out with ease. The seat belts are from a RR classic back seat and are mounted with 1/4" thick backing plates behind the bolts. I'm pretty confident in its strength. I mounted the seat back a bit for more leg room so had to do the same with the belts. This truck didn't come any rear seat belts when I got it. Front seats and belts are installed too.
My brother stopped over and helped me figure out why my turn signals and brake lights weren't working right. Had to do with a faulty converter designed to allow you to plug in a 4 pin trailer light connecter. Now I have to finish a bit of wiring, put in my windshield and wipers, and paint my doors.
Name:	2012-02-04 15.42.17.jpg
ID:	47359   Click image for larger version
Name:	2012-02-06 19.20.21.jpg
Name:	2012-02-06 19.20.38.jpg
ID:	47361   Click image for larger version
Name:	2012-02-06 19.21.32.jpg
Name:	2012-02-06 19.21.51.jpg
ID:	47363   Click image for larger version
Name:	2012-02-10 16.06.47.jpg
Name:	2012-02-10 16.07.20.jpg
Old February 11th, 2012, 07:16 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I like the seat install. Does the seat fit between the tub sides? Could you install it in the cargo area as a third row?
90 & 110 Parts Sale Extravaganza Wolf Fabrication For Sale - Parts 57 October 16th, 2012 09:35 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
